How many quarts?
Old Jan 7, 2001 | 06:29 PM
pookster
Naked oil covered babes who like max!
Sorry! I was forced to change my subject to get someone to look at my post :-) Does anyone know how many quarts it takes to change the gear lubricant in the transaxle on a 97' 5spd Max? Nissan does not seem to know since they decided to not include this spec in the owners manual!?!
[Edited by pookster on 01-07-2001 at 09:01 PM]
Old Jan 7, 2001 | 07:12 PM
Daniel B. Martin's Avatar
Five quarts
4.5 to 4.8 liters. Have 5 quarts on hand and you might have a little bit left over.
Old Jan 7, 2001 | 07:38 PM
pookster
Thx for the reply Daniel. I picked up 6 qts of Mobil 1 Synthetic GL-5 75w-90 today. I have 67k on the odo and with the weather on the cold side the shifting has seemed notchier that it has in the past. Hopefully the synthetic will help smooth it out.
Old Jan 7, 2001 | 07:41 PM
pookster
Thx for the reply Daniel. I picked up 6 qts of Mobil 1 75w-90 GL-5 today. With the cold weather shifting seems to be notchier than it used to be. Hopefully the synthetic should help smooth it out.
Old Jan 7, 2001 | 09:17 PM
I would reconsider putting GL5 gear oil in your tranny. You can still get synthetic GL4 75W-90 oil, for example, Redline MT-90. I put Redline in my car last year, but can't say it made a big difference.
Old Jan 7, 2001 | 10:42 PM
xHypex's Avatar
I put Redline in my transmission this past weekend, and I noticed a difference right away. I bought 5 quarts of fluid, but only ended up using about 4. It's somewhat difficult to get the fluid into the transmission without spilling, but I used ramps to help me out.
-hype
Old Jan 8, 2001 | 07:11 AM
Does your Owner's Manual specify GL-5 gear lubricant? My '99 Maxima calls for GL-4. There is good reason to avoid GL-5 unless your car was designed for it. For futher information, see the Pennzoil FAQ at http://www.pennzoil.com/carcare/faq/default.htm#4
Old Jan 8, 2001 | 07:35 AM
-hype
A good way to add gear lube to a 5-speed is to use a funnel with a 3-foot length of clear plastic tubing. The plastic tubing can be obtained at a home improvement store (Home Depot, etc.). Choose a diameter which is a snug fit on your funnel spout. 1/2 inch diameter fits well on my funnel. Position the funnel in the engine compartment, near the battery, and route the plastic tube into the transaxle fill port. Pour the gear lube into the funnel and let gravity do the rest. Take your time, gear lube is thick and does not pour quickly. Some minor degree of spillage is inevitable because the way you know the "box" is full is by observing an overflow.
Old Jan 8, 2001 | 07:52 AM
pookster
Daniel,
I found the same Pennzoil site that discusses the differences between GL-4 and GL-5; see https://maxima.org/forums/showthread...threadid=17763
I am glad that I posted my original thread before proceeding to fill the transaxle with GL-5!
Thx for the info..
rbuswell
Nov 17, 2016 04:54 AM
foodmanry
Sep 24, 2015 12:02 PM
pjgreek
Sep 9, 2015 09:30 PM
Moe
Apr 21, 2001 07:35 AM
bill99gxe
Aug 23, 2000 11:28 AM
