Stock pads with performance rotors?
Old Feb 5, 2003 | 09:15 AM
blakkrob's Avatar
How would OEM brake pads work with drilled/slotted rotors. As far as dust? And braking?
Old Feb 5, 2003 | 09:40 AM
Chunger's Avatar
My other car is a Hybrid
no braking performance increase...
Instead try OE style rotors with performance brakepads.
Old Feb 5, 2003 | 10:52 AM
blakkrob's Avatar
How about dust? I bought the rotors for looks anyway.
Old Feb 5, 2003 | 11:02 AM
BlueBOB's Avatar
Ok, I don't agree with that statement. I currently have performance rotors with OE pads and I stop soooo much better.
Of course, OE rotors with performance pads is good too.
And of course, both performance is best.
I love my rotors!
Old Feb 5, 2003 | 11:04 AM
96BLUMAX's Avatar
I noticed a difference with my performance rotors.
Old Feb 5, 2003 | 11:08 AM
99maxi's Avatar
most of us will notice improved braking when we change our rotors and pads no matter what brand they. the main point is that they are new and the ones u took off your car are old. of course new pads and rotors will stop better than old ones.
Old Feb 5, 2003 | 11:13 AM
njmaxseltd's Avatar
The stopping power is in your pads, not your rotors.
The rotors need to be able to dissapate the heat and keep the pads surface free from trapped gasses. Most like slotted for track use, they hold up better under extreme heat then X-drilled does.
X-Drilled are just fine for street applications, they run a little cooler then solid rotors do.
Axis Metal Master pads have very little dust. I'm currently running them on Stillen X-Drilled rotors. Which BTW is an awsome brake setup for street use. There are several other performance pads to chose from as well.
Old Feb 5, 2003 | 11:28 AM
96BLUMAX's Avatar
How much better are the metal matrix pads?
Old Feb 5, 2003 | 01:21 PM
Chunger's Avatar
Yep.... If you were to replace what you had in there originally with the same ones (new)... You would swear it was better... just because they were new...
But if you have the money... buy the nice rotors as well for the (mostly) cosmetics.
Old Feb 5, 2003 | 01:23 PM
Chunger's Avatar
Better than stock... I know this from experience... I changed mine from my original pads with only about 8K miles on them (and the car) although mine were the "Stillen" ones.
Old Feb 5, 2003 | 04:16 PM
matty's Avatar
When you do new rotors and pads do you need to get the rotors cut before there installed or no ??
Old Feb 5, 2003 | 04:32 PM
Chunger's Avatar
No... unless the new rotor is designed very bad (warped or bad finishing)...
Sometimes it helps to "rough 'm up" with some sandpaper but in general it's not necessary.
Old Feb 5, 2003 | 04:34 PM
matty's Avatar
"rough" 'm up" a rotor huh?? Im kinda scared
-matt
thanks buddy
BkGreen97
Apr 2, 2016 05:47 AM
Derrick2k2SE
Nov 19, 2015 10:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
