replacing valve cover gasket
Old Feb 5, 2003 | 08:40 PM
munji's Avatar
anyone done this lately?
and is there anything else I should replace while I'm there?
since it went out I also got a 303, oxygen sensor, would this be causeed from the gasket being out??
Old Feb 5, 2003 | 09:42 PM
karguy's Avatar
Re: replacing valve cover gasket
On underneath of valve cover there are a seal for each spark plug. I would definitely replace them when the valve cover is off. I would replace valve cover gasket and see if the problem goes away.
Old Feb 6, 2003 | 12:19 AM
JPMax's Avatar
What's next!?..
Definitely replace the spark plug cylinder seals.
Old Feb 6, 2003 | 05:30 AM
njmaxseltd's Avatar
The gasket has nothing to do with your O2.
Reset the ECU, if it comes back with the same code, replace it.
Old Feb 6, 2003 | 05:55 AM
ejj's Avatar
ejj
Don't forget to clean the surface of the old silcon sealend, and replace it in the same places with new stuff.
By "went out", what happened? Just leaked?
Old Feb 6, 2003 | 07:52 PM
munji's Avatar
My car feels like it is working too hard, and mileage started to go down drastically.
So, i checked my plugs and found some oil in the threads, and inner was burning dirty.
And I also got a front O2 sensor code.
Would these affect performance and mileage??
Old Feb 6, 2003 | 08:02 PM
karguy's Avatar
Significantly!
Matt93SE
Apr 8, 2018 09:23 AM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Nintensity
Aug 13, 2015 05:41 PM
