Changing UR pulley on Auto Maxima
I have UR pulley in garage. I don't know that I can install in it my MAxima Auto or not. Because I read the article from gregghome.com that I should have professional machanic install my pulley because my car is Automatic................ any suggestion?
Re: Changing UR pulley on Auto Maxima
With the manual you can put it in gear and it will hold, with the auto it just spins around and will not come loose.
There are 3 ways that I know of:
1. Pneumatic Impact Wrench.
2. Blip the starter with a strong arm held against the steering arm. (Thats the method I used)
3. Remove a plug and stick a rope down one of the cylinders, as much as you can get in there, then when you rotate the engine the piston will come in contact with the rope before TDC and prevent rotation of the crank.
The best way is #1.
The other two are risky.
Its not hard other than that and the fact its very close quarters working in there.
Jim
Maybe I'm totally wrong. But what if you left the car in gear and turned the car off? Would it have the same effect as leaving the 5-speed in gear? I doubt it because the whole auto tranny is viscious.
kenc15
Sep 25, 2015 06:38 AM
RealityCheck
Aug 5, 2015 06:18 AM
