auto climate control bulbs
I have a 99 max SE 5 speed and the switches for the temp control and the AMB(outside temp switch)don't lite up at night anymore how much of a big deal is this to replace? or will i just have to ive with it thanks.
No, they're replaceable. You have to take out the climate control unit and take the unit apart somewhat to access the replaceable bulbs. It's easy, just need philips and flat head screwdrivers. I did it on mine.
DW
DW
about instructions
Originally posted by rich1223
Ok good thanks alot for the info.Would anyone have the detailed instructions on how this is done?i am sure half the dash and the radio have to come out correct?
I replaced mine a few months ago also. Go ahead and replace all of them while you are back there. Just take the unit out and the bulbs are screwed in the back. You do not have to take any panel off or anything to get to them. Here is a link for removing the head unit but it will get you to the a/c too:
http://carstereohelp.com/stereoremovalNisMax2.htm
Good luck!
Good luck!
Same problem
I have the same problem with my 97 Maxima SE, one of the climate control bulbs went out. I'm getting the bulbs next weekend, I just want to know how long this repair will take. The audio removal site mentions that the clips for the ashtray will be lost or stay in place or something, but will I need to replace anything, or will this be easy? Are there any other sites with center console/ACC removal instructions, because my Chilton's manual only tells how to remove the whole dash. Thanks!
Re: me to
Originally posted by Indecisive311
Was wondering what kinda bulbs they were? 194? I was thinking about changing over all the bulbs to blue.
Thanks - CHad
Thanks - CHad
I have a 97 and mine were the easy kind to replace. I ordered my bulbs from Courtesy but I dont remember them being much over $2 each. That car stereo link is all you should need to get to the bulbs. Once that big piece with the radio and acc comes out just turn it around and you can access the bulbs.
I had the same problem last year. Use the carstereohelp website for instructions to get the dash apart--they were fine. Only remember to pull out and up on the vent/clock portion of the upper dash. It is a pain. The bulbs are easy though--they just screw in the back of the control unit. I'd recommend replacing all the bulbs whether they are burned out or not. You don't want to have to rip it apart again in six months for two $7 bulbs.
mikeg75
11-30-2015 05:12 PM
