Problem after UDP install
Old Feb 9, 2003 | 12:15 AM
hacim105's Avatar
I've installed a light crank pulley and now when I turn my car on the
E-brake light stays on and the battery light stays on. I even reset the ECU to hope it would go away and it hasn't. Does anybody know why this is happening? If you can help, I'd much appreciate it. It doesn't make any sense at all because I didn't tamper with either of those 2 things.
Old Feb 9, 2003 | 02:54 AM
96_vqmax's Avatar
Re: Problem after UDP install
Did your belt squeek?Check your alt belt tension and see if it's tighten problably.
Old Feb 9, 2003 | 08:00 AM
96BLUMAX's Avatar
Yeah that is weird. Never heard of those not going off.
Old Feb 9, 2003 | 08:46 AM
Lime's Avatar
uhmmm...that's really weird. You didn't touch the cables or anything while you were down there did you? Didn't touch any sensors? How did you do the install?
Old Feb 9, 2003 | 09:10 AM
hacim105's Avatar
I followed the procedures for taking the belts off. Pulled off the pulley put on the new one. Put the belts back on. Tightened them to as close as I could tell as they were before. Started my car and the lights just stay on. My car drives fine but that isn't cool. Maybe I'll check to see if the cables somehow got loosened, but I never touched any of that. And the E-brake is in the back of the car, how could that be affected?
Old Feb 9, 2003 | 09:20 AM
96BLUMAX's Avatar
Maybe its not from the ebrake but from the brake system.
Old Feb 9, 2003 | 03:17 PM
96_vqmax's Avatar
I think it's more likely that he prolly accidently knock a wire loose or something on the alternator for the battery light to come on.Make sure that the plug on the alt is plug in all the way in.Good luck.
Old Feb 9, 2003 | 06:34 PM
ny96max's Avatar
this is why i had Jeff at Max Tuning install mine
Ant
Old Feb 9, 2003 | 06:38 PM
«§»Craig B«§»'s Avatar
check the tension on teh alternator belt (and check its connections too)
on 3rd gens, ebrake light + battery light = alternator so I'd guess it's probably similar for 4th gen
be careful, if your alt. isn't working, you wont get very far until your battery dies
Old Feb 9, 2003 | 07:16 PM
mtrai760's Avatar
'Trynna' is not a word
Yup, if your alternator is not functioning properly, you will get a brake light on as well. I'd start looking in that area, maybe you knocked something loose or damaged something?
Old Feb 9, 2003 | 11:00 PM
hacim105's Avatar
That's what it was the alternator belt wasn't tight enough. It wasn't a big deal. Almost drained my battery though. I'm glad I figured it out.
Old Feb 9, 2003 | 11:24 PM
96_vqmax's Avatar
No,you mean we figured it out.J/K hehe glad you fix the problem before it kill your battery.Peace!
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
