Completed Intake!!
Old Feb 10, 2003 | 03:50 PM
cantgofast's Avatar
Completed Home made Intake!! Opinions?
I finally made an intake!! With the help of my father, we made a nice home made intake for about $30 using a PVC drain, a metal plate and an APC filter. Look at page 2 of my homepage which I made tonight and there are pics of it as well as how we made it. I am going to install the temp. senser to the end of the filter. Let me know what you think!! Thanks!!
BTW I have not yet installed it, but when I do I will post.
Old Feb 10, 2003 | 05:41 PM
cantgofast's Avatar
Think the PVC will be OK?
Old Feb 10, 2003 | 06:42 PM
cscm094's Avatar
I heard somewhere plastics are better than metal b/c they do not transfer heat as much as metal ones do.
Old Feb 10, 2003 | 06:46 PM
henock
wouldn't you want the heat to be dissapated? aluminum is the best at doing that
Old Feb 11, 2003 | 07:23 AM
cantgofast's Avatar
I figured that because the entire stock intake sys. was made of plastic, it would be ok to use plastic. Also, i think that where the adapter will be located, it will not experience too much heat.
Old Feb 11, 2003 | 08:15 AM
Stephen Max's Avatar
You have to think of the direction of heat flow. In this case, you have cool outside air being drawn into the engine. You do not want the intake air to be heated up by the engine heat, so a thermally insulating material such as plastic is best for an intake pipe. Same reason why some people use heat wrap on intake pipes.
Old Feb 11, 2003 | 05:56 PM
cantgofast's Avatar
Installed Intake!!!
Damm it sounds good!! Pulls a little harder too, even though I didnt go fast, as my name implies!!! now i need a midpipe!! i am VERY pleased!!
Fbana41
Aug 29, 2016 12:18 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
maxima297
Sep 24, 2015 08:57 PM
Keyno McMike
Sep 21, 2015 07:18 AM
220k+ A32
Sep 11, 2015 02:18 AM
