Rewired Fogs and now
Originally posted by MaxEffect414
um, lol try a bigger fuse.....
Mine blew untill i put a 10amp in there, just buy some 10 and 15 amps fuses and put in a 10 amp
Umm, no. Not unless you feel like rewiring parts of your car.
If you are blowing fuses, you did something wrong.
By rewire, what do you mean? Do you mean being able to run them separate from the headlights?
I did this a year ago, and have had no problems with fuses what so ever.
Originally posted by cscm094
um no, don't... unless you like electrical fires. Thats plain stupid. There must be something shorting somewhere. Recheck all your connections. I rewired mine without any problems of fuses.
And also, while you are doing this, do the quick easy rewire to get ure blinkers and sidemarkers to alternate... and oh yeah, splice an extra ground wire to the chasses for the fogs and headlights. I actually noticed mine get brighter after this. Same thing as the oogly hyperground mod but this is more directly related to the lighting. Good luck!
Electrical fires huh lol, i have had my 10amp fuse in for like what now 2 years plus i have done some other stuff and used bigger fuses with no problem, just as long as you don't go too big it's perfectly safe.
mine kept blowing and i just put a 10amp and it's great, i even have my fender side lights connected to it.
Trust me, it will not mess up your car, put in a 10 amp and turn on all your lights and high beams and interior lights and step on the gas a bit and check your engine bay and see if anything starts to smell which it won't.
Trance
Trance
Originally posted by nadir_s
ohh well, I know goin w/ bigger fuses is a no-no, but I had to put in a higher fuse because I kept blowing mine. Although, I thought the 97+ didn't have this problem... I'm a 96, and the steps i used didn't work so I just changed the damn fuse. I run just my fogs and corners for a long time now (half a year) and no problems. I say just change the fuse to 10A.
Originally posted by 98GLEMaxed
What do u mean ground the fogs? please tell me how you did this. i have rewired my blinkers. it is cool. i want to do the same to my rears.
Yea I rewired mine and never had to change the fuse. All your doing is keeping that relay open. It might draw a little more current when you have the high beams and fogs on, but like I said, I never had to change any fuse. It definitely shouldn't blow a fuse when it's operating in the condition that it was able to before (low beams and fogs). You didn't do it right.
-Nick
Originally posted by 95CustomMaxima
I have a 95 and followed the steps word for word and had no issues with the fuses for a couple months now.
-Nick
-Nick
Quick question tho, when you switch from just the parking lights to the headlights, does the fogs get brighter? Actually for me it's the fogs and corners that get brighter... jut by a little bit tho. Oh well! all's good.
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
Calabar
10-05-2015 09:57 PM
