no O2 codes, KS, but bad gas mileage, help
Old Feb 12, 2003 | 12:10 AM
sebaxx's Avatar
i have a very bad gas mileage. My car is almost 16 mpg city, i dont know if im drive a shorts distance(6 miles sometimes) and most of the times are hills but dont high slopes.
I dont have any O2 codes, do i have to change the sensor after 130,000 miles?? my max is 95 gxe auto.
Sometimes my cel pull me 0302, 0304 like 1 time per month, but after 2 weeks not codes
What else do i have to check? i remplaced, plugs, tranny fluid, fuel filter, pcv, belts, clena TB, IAC, EGR.
Old Feb 12, 2003 | 01:35 AM
Eric L.'s Avatar
16mpg city sounds normal to me. Especially for an automatic Maxima.
Old Feb 12, 2003 | 05:11 AM
Lime's Avatar
that's not very far off from what it should be. Depending on how you drive as well, it's not very bad. I think we're only supposed to get around 20-21 mpg city at the best of times.
Check your EGR components ... and clean your AICV...which I am about to do as soon as it's not 15 degrees.
Old Feb 12, 2003 | 05:27 AM
Mishmosh's Avatar
Re: no O2 codes, KS, but bad gas mileage, help
Try pulling the codes even without a CEL.
0304 by itself will not light up a CEL.
Just realise also that in the cold season and with city driving, you should probably get 18-20mpg so you are not far off. Just keep checking the mpg for the next few tanks. Also, I hope you are using premium fuel and have NGK spark plugs.
Old Feb 12, 2003 | 08:19 AM
Lime's Avatar
also, have you every used fuel system cleaner? Your injectors could be dirty.
Old Feb 12, 2003 | 10:40 AM
sebaxx's Avatar
yes, i cleaned my injectors a few weeks ago, clean the IAC, EGR system, maybe is normal here where a live, theres a lot of hills and that S...t.
mvm062
Nov 30, 2020 09:00 AM
Maximan190
Dec 16, 2015 06:01 AM
dcam0326
Sep 7, 2015 07:26 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
