HELP starting up problems
Old Feb 13, 2003 | 12:38 PM
sunnyb32's Avatar
HELP max is NOT STARTING up!
ok i tried starting my car yesterday and it took like 10 mins to start it and it evenutally did but i was like wtf? and plus then i turned it off and tried starting it again and it started perfectly..so now this morning when the car is ice cold -4degrees here it does it again!! and today it didnt start at all i had the tow person come and someone how he got it to start after pushing it for about 20 mins...this is really odd i donno whats wrong and no one can find out please help..i dont wannta take it to the DEALER i JUST new starter PUT IN for 600$ damn... jus 14 months ago
the car is 95GLE with 125k
help is appriciated thanks alot
Old Feb 13, 2003 | 02:16 PM
Kevlo911's Avatar
Kevlo for President
Re: HELP max is NOT STARTING up!
my car used to not start in cold weather, check battery fluids levals and my mom used to get hot water in a pot and pour it on the engine and it used to start
Old Feb 13, 2003 | 03:22 PM
stockacura's Avatar
I had problems with hard start in cold weather. Changed many parts including starter, pcv, ects, fuel filter, spark plugs, cleaning throttle body. Try searching in the forum for "start" and you will learn alot.
For your problem, it is probably a bad sensor or stuck pcv etc. so start by changing cheaper parts yourself like ECTS, PCV, Fuel filter, spark plugs(get the cheaper copper if you are in budget)and cleaning the throttle body.
Good luck!
check out motorvate.ca for DIY instructions on how to change above parts.
Old Feb 13, 2003 | 04:03 PM
tbannon's Avatar
i have a 95 gle too more mile than you and i have gone through 2 or 3 starters. i don't really know what could be wrong probably dealer put in a shtty starter. next time don't let them put in the starter especially for 600 thats outragous go to local auto part store get one with 10 teeth i think thats right(somebody correct me if im wrong) and then just put it in yourself takes 20 - 30 minutes.
http://www.motorvate.ca/auto/maxima/starter/starter.htm
Old Feb 13, 2003 | 07:41 PM
95maxima's Avatar
I'm gettin' tired of dealers STEALING from car owners!!! $600 to change a starter??? Thats OUTRAGES!!! They need to pass a bill on Congress to prevent dealers from charging hideous prices for simple repairs, such as the predatory lending bill which was recently passed here in GA.
Old Feb 14, 2003 | 12:06 AM
Black97GLEnj's Avatar
This just happened to me the other day. I knew it wasn't the battery, alternator, or starter, so as soon as it finally started (took a few hours) I drove it right to my mechanic. It turns out I wasn't getting a spark. The plugs which were about 25k miles and 18 months old were black. I got new plugs, cleaned throttle body, and fuel injector cleaner and it runs great.
cold weather + driving with bad thermostat for a week = black sparkplugs
Old Feb 14, 2003 | 05:50 AM
njmaxseltd's Avatar
Crank Sensors - There are two of them, one just below the lower pully (REF) and the other is on the bell housing and looks at the flywheel (POS).
They seem to accumulate some micro fine metalic dust on the pickups which causes a weak signal to the ECU. Take them down, clean them up and put them back in place. Your car should start with one crank!
Old Feb 14, 2003 | 11:16 AM
95maxima's Avatar
my car had the same prob. just today and i pulled the codes (P0340) camshaft pos. sensor. i got one from napa ($70) and the car turns on flawlessly
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
