Broken Antenna.How Much To Replace
Old Feb 18, 2003 | 08:20 AM
maxperformance's Avatar
I Went through a car wash and the dam guy that drove my car in there forgot to turn my radio off, so the antenna was up the whole time. So the antenna broke, and now everytime i turn the radio on or off i hear the little motor running or trying to retract the antenna thats not really there. (I still get great radio reception) So if i go to nissan how much will it be to get a new one. Buy I dont think i need a new motor or anything becuse its still running, there just no antenna in there.
And if i were to do it, how do I even get to the antenna thing?
Thanx Guys.
Old Feb 18, 2003 | 08:40 AM
ghetto_bill's Avatar
My antenna also broke when my I went through a car wash. I got it replaced from my local Nissan dealership for $110CND, which is about $70USD. Too bad my deck broke, so I don't have any music when I drive around. I won't get it back for another week or two.
Old Feb 18, 2003 | 08:44 AM
maxfanfromohio's Avatar
Shiver me timbers.
I did the same thing at the car wash. I had mine replaced at a Nissan dealership and I also think it was around $70.
Old Feb 18, 2003 | 08:50 AM
gepetto's Avatar
If you just need a new mast, I'd try a junkyard first. Should be pretty cheap. And I think its a DIY job.
Old Feb 18, 2003 | 09:03 AM
Jshock1's Avatar
I have a problem with my antenna too, but it didn't break. It's just stuck half way out. I tried putting WD-40 but that ain't working. I haven't tried to force it down either, but I don't wanna break it. Could it be the cold weather or the 20 inches of snow we got yesterday??
Old Feb 18, 2003 | 09:21 AM
98BlaximaSE's Avatar
Dealership wanted $200 to replace the whole thing. Got a whole new unit off ebay for $40 or so. Installed it myself, pretty simple job, just plug and play.
Old Feb 18, 2003 | 11:11 AM
jbreit's Avatar
A new factory mast retail is $32 and can be replaced yourself fairly easily....the instruction should be in the forum somewhere....or buy a haynes manual....the drive assembly retails for closer to $170, and does not include the antenna.
I bought a factory antenna replacement mast for my car and since converted to a rigid antenna cause the drive assembly was screwed up....its yours if you want it...new, never used, $28 delivered to your door.
Old Feb 18, 2003 | 08:16 PM
taggate's Avatar
First you can check ebay.com for a replacement or
Second just unplug the antanna (i did that and the reception is find, even in tunnels)
Old Feb 18, 2003 | 08:25 PM
Geophrum's Avatar
I bought a replacement ant mast from pepboys that was for my car for like $15 but the problem is i can t remove the mast from the motor in my 96 GXE... they look identical but the mast doesnt come out like it says in the hayes books... it looks like it is sealed in there
Any help on removing it?
Old Feb 19, 2003 | 07:58 AM
95maxima's Avatar
i bought a factory mast form the dealership for $50 and put it in the motor myself. The old broken antenna would not come out like the people at the dealership said it should so i had to take the motor apart, pull the old one out, and wind the new one up and put it in. Took about 20 min. and it was pretty simple.
Old Feb 19, 2003 | 10:27 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Re: Broken Antenna.How Much To Replace
Same thing happened to me by accident about 3 yrs ago on my '98 Altima GLE, didn't even know I had the antenna still up at the time while going thru a car-wash. That was a costly $87 lesson I've learned to always keep the antenna down when entering a car wash
Old Feb 19, 2003 | 12:03 PM
99CTMAXSE's Avatar
98Blaxima, Do you know which antenna you purchased on e-bay? It looks like one seller sells a herschman brand and the other sells a metra. I need to replace mine, I want to know which one you had good luck with.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
tnewbs
Aug 28, 2015 10:15 AM
