Vibrating when accelerating
Old Feb 18, 2003 | 08:40 PM
MaxgtrBlue's Avatar
Hey, I need Help im stuned! I just lowered my car a week ago with proggress springs and kyb shocks. Then a few days later I noticed when i push on the gas pedal and the speed is hitting above 40-50mph i feel a weird grinding vibrating sound. I feel it on the pedal and on the chair.. I also hear like a grinding vibrating noise and i dont know what it is.. IT only happens above 40mph and defintly at 50 mph.. IAT first i thought it could be an allignment problem but then figured it cant be becuase it only happpens when im pushing on the gas pedal, it goes away right after i let go of the pedal?
What can this be? Please help me? Thanks .....
Old Feb 18, 2003 | 10:11 PM
HarrisH's Avatar
Might sound dumb but it could be your wheel balancing, wheel alignment, or bent rim. If you rule all these out might be a suspension problem.
Old Feb 18, 2003 | 11:25 PM
iansw's Avatar
http://forums.maxima.org/showthread....n+accelerating
(Make sure you read the whole thread, because it was quite a journey for me to find the problem)
If it's mostly there when accellerating:
Your car is too low, the roads are too bad where you live, and you've got a bad Inboard CV Joint - probably driver's side.....when mine started going out, it took 3 in 3 months - so they go pretty quick....
I actually have a "new new" one sitting in my living room right now. Luckily I raised the car on higher springs, so this should be the last time.
Call Marti at raxles.com....great service, lifetime warranty.
Old Feb 19, 2003 | 12:46 AM
Miasma's Avatar
is this common with lowering?
the axles showed NO signs of problems at stock height?
iansw, what springs do you have now?
Old Feb 19, 2003 | 09:09 AM
iansw's Avatar
My passenger axle is going right now, but since I raised it back with B&G Springs, it seems fine - symptoms are gone.
Old Feb 19, 2003 | 09:28 AM
funnylittlman's Avatar
Ian,
I think i have found out what my vibration is coming from. I had some hubcentric weights put on my car when I had some Khumo's on my car. I have since put some dunlop sport a2's on there, and NTB put on outside weights again. They assured me that they would take off all the hubcentric weights and do it correctly. I just took their word for it....
Anyway after taking the car back there 3 times arleady, I decided to check and see if they took off all the weights. To my dismay, my front right wheel has some on there left. NO Wonder there is a shimmy! I haven't gotten it balanced again yet, but rest assured I'm gonna rip someone a new a$$ when I go back!
If not, I don't know what it could be. CV Boots and joints all taken care of.
Old Feb 19, 2003 | 09:39 AM
iansw's Avatar
Originally posted by funnylittlman
Ian,
My boots looked perfect too.....
I hope it is just balancing - but if it was , it wouldn't happen only under accelleration.....it would happen above 40-50mph all the time.
Old Feb 19, 2003 | 09:44 AM
I'll let you know
Old Feb 19, 2003 | 10:55 AM
Miasma's Avatar
did sprint springs cause the prob? if not, which?
Old Feb 19, 2003 | 10:31 PM
98maxsel's Avatar
maybe you need a balance and alignment?
Old Feb 19, 2003 | 10:33 PM
iansw's Avatar
Not just Sprint Springs, but a combination of factors -
1) Not cutting the bumpstops
2) Bad roads
4) Sprint Springs
All of these contributed equally, I think.
Old Feb 19, 2003 | 11:51 PM
Miasma's Avatar
2) Bad roads
4) Sprint Springs
not cutting bumpstops? what does that do, and how do i cut the bumpstops? when is that a good idea?
Old Feb 20, 2003 | 12:21 AM
iansw's Avatar
Whenever you're dropped below 1.8 inches - I don't know how - because i never did it - I just got higher springs....
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Need help
23
Oct 2, 2015 08:56 AM
06maxima55
Sep 28, 2015 04:29 PM
