Car is giving me problems.
Old Feb 19, 2003 | 06:02 PM
MaXAnDy's Avatar
Like a week ago i posted that my car would give jolts while it was in drive or reverse while going at very low speeds or if at idle in drive or reverse. It acts perfectly normal in Park though. Well i changed the spark plugs and now the jolt while standing still in Drive and Reverse are very rare but the car still does it. The difference now is that when i am braking from whatever speed when it is almost coming to a complete stop it gives a hard jolt. It does not do this every time. Someone please help
Andy
Old Feb 19, 2003 | 07:18 PM
sil SE's Avatar
"Car is giving me problems."
you need to smack it in the face and say "who's yo daddy!?"
then, if youre a 5 speed..make sure youre not slowing to 5mph in 4th gear. if its an auto. i dont know.
im turning into a pw this is bad.
Andy
Old Feb 19, 2003 | 10:29 PM
98maxsel's Avatar
Old Feb 20, 2003 | 05:45 AM
njmaxseltd's Avatar
You have a misfire.
Have your fuel system cleaned - Throttle body and Injectors.
Check your coil packs - Make sure the connections are good and solid. Also check the ground points near the fuel rail. Make sure there clean and solid.
Has your ECU thrown any codes?
Old Feb 20, 2003 | 07:39 AM
max83's Avatar
Re: Car is giving me problems.
Andy
Mine used to buck and stall in drive or reverse and stall out also.
I just took off my TB and actuially scraped the crap off with a scraper. That cleared my problem up.
Old Feb 20, 2003 | 08:40 AM
MaXAnDy's Avatar
the car was giving the egr code and my mechanic checked it out and cleaned it up and he says thats not it.
This all started after i had a tune up and changed the oil, fuel filter, and spark plugs. A week later the ecu code turned on giving hte egr code. My mechanic turned it off, but a day later it turned back on, i took it back and he cleaned the egr and he changed the plugs again. And the problem is like i stated above. By the way i am auto.
Old Feb 20, 2003 | 08:41 AM
sil SE's Avatar
visual inspection?
maybe i should do this.. what do you think? it popped a multiple misfire code but no specific cylinder, and now its reset and after at least a hundredsome miles, no problems
Old Feb 20, 2003 | 09:22 AM
MIXXMAX's Avatar
What kind of plugs are you using?
Old Feb 21, 2003 | 04:43 AM
MaXAnDy's Avatar
my mechanic said he ordered the pkugs from nissan.
Anyone else have some useful info?
Old Feb 21, 2003 | 05:31 AM
njmaxseltd's Avatar
Take the coils back out and inspect the electrode stalk that goes to the spark plug for any signs of cracking. A few have said that wraping it with a layer or two of electrical tape has helped cure misfires.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
xUNIxPanther
Aug 27, 2015 10:09 PM
dauntlessmax
Aug 5, 2015 10:29 AM
