rear suspension noise
Old Feb 20, 2003 | 06:29 AM
neck's Avatar
i have about 70k miles on my max.
when i go over speed bump. my rear suspension makes a thunk noise when the car is comming down from the bump..
any clues?
Old Feb 20, 2003 | 06:43 AM
Lime's Avatar
sounds like a busted rear shock, but if you do a search for suspension noise you will come up with a million things it could be.
The best way to test a rear shock is kind of annoying, but try to tighten the inner nut (you need a deep socket wratchet and an adjustable wrench for this). If it just spins, the seal is bad.
It could also be...
spare tire is loose
trunk liner is loose
If you remove the trunk liner and look around, you can see the tops of the rear shocks. If there are any anomales in their appearance (one is higher than the other or something), that's a good indication one is busted.
Old Feb 20, 2003 | 07:09 AM
njmaxseltd's Avatar
Not true.
Sorry Erica.
The pistons will spin, there supposed to.
Old Feb 20, 2003 | 10:09 AM
neck's Avatar
and if the shock is busted.
can i still keep driving on it until it gets warmer.. like 2 months?
the tire will wear un-evenly..are there other affects?
It could also be...
spare tire is loose
Old Feb 20, 2003 | 10:13 AM
MaximaRider's Avatar
Stock suspension? Blown strut...
Old Feb 20, 2003 | 10:25 AM
neck's Avatar
donno. a clunking noise when i go over speed bumps (or speed bump like bumps). sounds like it's from rear suspension.
Old Feb 20, 2003 | 12:15 PM
funnylittlman's Avatar
Have you checked all loose items in your trunk? I.E. tire jack, etc?
Matt93SE
May 24, 2019 02:58 PM
maxinout93
Oct 27, 2015 01:29 PM
Huttig2009
Sep 25, 2015 03:31 PM
A32goldylocks
Sep 2, 2015 06:39 AM
george__
Aug 18, 2015 07:06 PM
