interior lights
Old Feb 20, 2003 | 08:33 AM
KGBSJU's Avatar
interior lights
This sounds strange but when I push down hard on my brakes the interior lights in my car turn on....well just the dome and front door lights...what could that be?
Old Feb 20, 2003 | 09:03 AM
97blackSE's Avatar
what could that be? WEIRD!!!...and ANNOYING!!!
Old Feb 20, 2003 | 09:15 AM
dvpatel99se's Avatar
Re: interior lights
What could that be?? It seems that you are pinching some wiring by the brake pedal. Better fix it quick before the wires get cut or else some lights will totally quit working.
Old Feb 23, 2003 | 09:29 AM
KGBSJU's Avatar
Re: Re: interior lights
ok thanks...ill check that out
Old Feb 23, 2003 | 10:21 AM
95emeraldgxe's Avatar
lol that is one of the funniest things i've ever heard - check your grounds
Old Feb 23, 2003 | 01:32 PM
Chunger's Avatar
My other car is a Hybrid
Like stated above... door switch circuit:
Check the door switches or check for a grounding door trigger wire to the aftermarket alarm near your break pedal (probably green in color)
Old Feb 23, 2003 | 01:43 PM
Speebs's Avatar
I aim to misbehave.
Is this when you're moving or when you're stopped? If moving, then maybe the switch inside the door is loose and the extra force exerted by the door is causing the lights to come on. Seems unlikely, but if your wires are okay...
Old Feb 24, 2003 | 05:19 AM
multiplexor's Avatar
maybe when you press on your brake pedal, the extra lights that pedal lights up, drains more power from your battery and makes your lights dim?
could this be fixed with a hyper ground system? or even the DIY kind...?
Maximan190
Dec 16, 2015 06:01 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
