AGX and Eibach Pros are in!!
Well after 2 attempts, a blizzard, and a slow delivery guy, my AGX's and Eibach are in, and im loving the ride. Beats the hell out of stock, and whats even better is no more 4x4 look. Before and after Pictures coming soon. Big thanks to Jeff over at Maximum Tunning for another great install job.
Originally posted by DanSE
Nice man! Looks much better. By the way, how much did Jeff charge for the install? and how long did it take? I am going with the exact same setup and I've had work done by Jeff so I know he does a good job.
Info on Jeffs shop can be found Here
Originally posted by Lime
wait two weeks and take a pic.
also get an alignment at that time.
Originally posted by Norel
The car isn't pulling at all so far, and if these tires get bad wear, who cares they are gone come the spring
Toe changes when you lower your car. It's the geometry of our suspension. Once you crack the lower strut bolts lose, your toe setting is gone. Lower it, and it's off even more. The fact that it's not pulling means your camber is within spec on both sides. The install was done correctly.
maxima-junky
10-07-2015 06:13 PM
