help diagnose problem please
Old Feb 20, 2003 | 07:43 PM
Dev's Avatar
Dev
yesterday i was redlining my gears....as i heard a bang in the engine bay (sitting in the drivers seat).
as i hear the bang, there is a pause in acceleration, almost a jerk (like the throttle skipped).
so i stop going fast, and at about 4k rpm i get this again going WOT.
i drove slow the rest of the time, and had no problems.
today when im driving, low rpms (1000-2500rpm) has this jerk in acceleration in gears 1 and 2, not the higher gears.
by jerk, its like a pause in acceleration for a split second, which jerks the car.
from searching, i think it may be ignition coils or something.
i have a 99 5spd with 60000km, was running amazing before yesterday.
i have not done a tb cleaning ever.
just hoping its not the transmission.
thanks in advnace,
Dev
Old Feb 20, 2003 | 07:49 PM
iansw's Avatar
Re: help diagnose problem please
thanks in advnace,
Dev
Any Engine Codes?
The first symptom (bang!) seriously sounds like a popped engine to me, but the fact that it's inconsistant tells me its something smaller - coil, injector, etc, etc....
How's it idle?
Old Feb 20, 2003 | 08:28 PM
Dev's Avatar
Dev
Re: Re: help diagnose problem please
Originally posted by iansw
Any Engine Codes?
How's it idle?
right after driving hard and letting the car idle in the parking lot...the idle was lower than i ever saw it, at about 550rpm.
its usually at 750 all the time.
no engine codes thus far.
Old Feb 20, 2003 | 08:55 PM
iansw's Avatar
Re: Re: Re: help diagnose problem please
probably not a popped engine then - check plugs, coils, then injectors.
Old Feb 20, 2003 | 09:20 PM
Dev's Avatar
Dev
Re: Re: Re: Re: help diagnose problem please
do you think it has anything to do with clutch or tranny?
i'm really hoping these aren't the problem, because they were fine two days ago, and its not like a misshifted or anything.
im going to check the coils with a friend.
what can i do about injectors?
Old Feb 20, 2003 | 09:22 PM
iansw's Avatar
Re: Re: Re: Re: Re: help diagnose problem please
Unplug each coil from the harness one at a time.
If the idle doesn't change or move after pulling one of them, then that's your bad coil/injector.
Then swap the coil in that cylinder with a known good one - if the idle now changes after pulling the harness, then it's the coil - if it still doesn't, it's the injector.
But make sure the spark plugs look good first, of course, because it could be that either way.
Old Feb 20, 2003 | 09:45 PM
Dev's Avatar
Dev
Re: Re: Re: Re: Re: Re: help diagnose problem please
ok thanks so much for your help
my friend is quite a bit more knowledgable than be with this stuff, so ill ask him to take a look at the plugs while doing the coils.
so you don't think its the tranny or clutch right?
Old Feb 20, 2003 | 09:48 PM
iansw's Avatar
Re: Re: Re: Re: Re: Re: Re: help diagnose problem please
I don't own a 5spd (yet, it's on the way), so it's hard to say....but if it's a lag in accelleration when you're hitting the gas without your foot on the clutch, I don't see how it could be the tranny or clutch, since you're not using it.
IanS
Old Feb 20, 2003 | 09:54 PM
Dev's Avatar
Dev
Re: Re: Re: Re: Re: Re: Re: Re: help diagnose problem please
IanS
yes my foot is completely off the clutch.
when i was driving hard yesterday, it was doing this in gear 3 and 4 as well.
from the hesitation in acceleration, i thought my clutch might be slipping. however my car only has ~38k miles on it. the clutch was fine before, grabbed pretty hard for stock. im not sure what a slipping clutch feels like, but when i redlined 2nd gear today, it held up fine.
im just worried about the "bang" sounds i got yesterday, that didnt seem right at all.
Old Feb 20, 2003 | 10:22 PM
Dev's Avatar
Dev
ok i've been reading over some threads, and a better word for my problem would be a "hesitation" or "hiccup" in acceleration, if that makes it easier to understand.
i didn't really know how to explain the problem too well.
Old Feb 20, 2003 | 10:37 PM
iansw's Avatar
Yep, like I said, probably not your tranny or clutch - you only feel a clutch slip when using it....
Old Feb 20, 2003 | 10:42 PM
Dev's Avatar
Dev
ok sounds good
thanks for your help
Old Feb 20, 2003 | 11:41 PM
Mr.95GXE's Avatar
Shouldn't be the clutch. I have had my stock clutch in my '95 GXE since I pruchased it new in '95. My car now has 178k miles and it still has the factory clutch in it and slight slipping when I shift from 1st to 2nd gear at full throttle. Other than thatit holds up fine.
Old Feb 21, 2003 | 12:42 PM
Dev's Avatar
Dev
im pretty sure its not my clutch...its in good shape.
but if the problem IS my coil packs, would it trip my CEL?
right now the problem is only at first and second gear below 2500 rpm, but the engine hiccup is inconsistent, it only happens sometimes.
Old Feb 21, 2003 | 01:07 PM
iansw's Avatar
I'm leaning towards a fouled plug, myself - but hwo knows....coul even be a vacuum leak.
Have it looked at.
Old Feb 21, 2003 | 01:11 PM
Dev's Avatar
Dev
Have it looked at.
im not sure if its a vacuum leak, cause when i was driving hard 2 days ago, it was like someone took a baseball bat and smacked my engine. thats the kind of noise there was.
Old Feb 21, 2003 | 01:13 PM
iansw's Avatar
Probably a misfire - vacuum leaks cause those too.
You should have the entire car looked at - plugs, coils, injectors, hoses, compression test, Oil Analysis, etc, etc, etc....
Might save you an engine down the line.
Old Feb 21, 2003 | 02:34 PM
Dev's Avatar
Dev
i just switched to mobil1 10W30 synthetic a month ago, so the oil is brand new.
i will have the plugs, coils, and injectors tests with a friend soon.
ill ask him about the compression test as well.
this is so weird, my car was running absolutely perfect before this
Old Mar 10, 2003 | 07:26 AM
maximumpower96's Avatar
Dev, is your car running fine now ? if so let me know because i am having the same freakin problem in 4th and 5th gears
-Sal
Old Mar 10, 2003 | 10:50 AM
diegomax's Avatar
Yea, generally with stumbling
1. check for codes
2. check plugs
3. check coils
3. check inectors
25 minutes total
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
