Engine coolant temp sensor
Old Feb 21, 2003 | 02:14 PM
hacim105's Avatar
What makes that sensor go off? My coolant is full. I don't understand what the problem would be. If you can help thanks.
Old Feb 21, 2003 | 02:26 PM
Mishmosh's Avatar
Re: Engine coolant temp sensor
If you are getting a code, chances are it has failed. It is even possible for a bad ECTS to be giving off bad readings (on coolant temperature) and not giving off a code. Has nothing to do with how much coolant you have in the system. It is not an expensive part so don't feel bad if it needs replacing.
Old Feb 21, 2003 | 04:05 PM
metallic97gxe's Avatar
Master Will
just seconds ago...I bought one for $26.00 and will be putting mine in tommorrow...
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
captchaos
Mar 15, 2016 12:18 PM
lux97Max
Sep 4, 2015 05:42 PM
dcardello
Sep 3, 2015 11:44 PM
