My OBX is in !!!
My OBX is in !!!
Its quiet...really quiet
but I like it..I have to go over to Mineike tomorrow to see about getting the b-pipe heated up and bent do its not hanging down any more and its makeing alittle noise at idle and when I hit bumps and stuff... It fit pretty good and I paid someone to losen all the bolts and stuff
Im definetly going to be getting a test pipe to make it alittle louder..there is like zero drone
-matt
-matt
Im probably going to get a test pipe now to make the car alittle bit louder. Sometimes you cant even hear the exhaust, but in some ways, thats good. Im going tomorrow to Midas or Mineike to get the b-pipe heated up, and bent up alittle bit, then ill align it really good to the bumper...I also have to decide if Im going to ask to have the guy chop about 1" off before the muffler then reweld it and put it so its flush with the bumper...I dont want to have it hacked, then when I get my test pipe, it be shorter than the bumper..
what do you think ??
-matt
-matt
It's only about 1-2" too long but I may have that corrected tomorrow morning when I go to get the b-pipe twisted..I may not even fu** around with the length till I get the test pipe just to make sure that doesnt change anything
-matt
-matt
-matt
-matt
i have a 97 and mien sticks out like half an inch to an inch max, which i'm happy with, actually want it to sit flush wit bumper and thats good enough, have it stick out a little....but yea i also had meineke heat up the pipe so it fit better. A test pipe will make the sound greaten but just make sure u get the right one, u dont want a nasty raspy sound to follow u around....i'll take it u dont have a y-pipe? or u do and its still too quiet? i guess they and our opinions met your expectations
I got back from minike and they did what they can do...They heated it up altitle bit but its still not perfect. They guy said it really doenst fit the car all that good, but Im satisfied with it
It is a very quiet exhaust even with the y-pipe. When you do get on it, it sounds really good all the way up the power band, witch surprised me becasue i thaght it gets drowned out from the intake..and the purr of the exhasut is hella good. I feels alot more linear through the gears but quiet as h*ll... Next is the test pipe to see if I can get it a tad bit louder then ill align the tip to the muffler
-matt
-matt
-matt
-matt
I heard its straight threw, but from the a*s hole we bought it from, it could not be
I like it..I need a test pipe now
-matt
-matt
I filled my hole on my 97 with a bolt and muffler cement, what did you use? Mineke quoted me to 40 dollars to weld it shut, I got the damned thing installed for forty, I told them to go suck a ****.....
i agree about the sound being quiet, the intake sound drowns the exhaust out ot 3000rpm, I like the stealthy approach so this is sweet. Im going tomarrow to see if this guy I know can maybe make it fit better, the only problems that I have is that right befor the rear tire you can see about 1.5ft of shiny pipe hanging down from the side of the car, and the bpipe rests on the middle support tie that is in the center of the car where the hanger is. this caused rattleing so I rigged a piece of that fiberglass stuff from the stock exahaust inbetween the pipe and support to make the rattle stop. other than that my tip fots perfectly and is flush with the rear bumper.
Originally posted by 95emeraldgxe
its so quiet that you gotta get a straight pipe to make it louder? - dam thats a first
Nah the thing is, I have a y-pipe...Im on the highway at 80-3200rpms and I can barely hear the exhaust at all. At WOT it sounds sweet all the way up...im happy it doenst drowned out by the intake
I filled the o2 sensor hole with just a bolt...it did the job good
-matt
i have a custom catback exhaust , i had a b-pipe bent up and it has no resonators and i have a universal muffler . It is louder than any afthermarket exhaust i heard on a maxima. Im worried than when i put my y-pipe it will be to loud , what do you guys think?
VQ'ed
69
Aug 27, 2020 12:29 PM
kenc15
Sep 25, 2015 06:38 AM
