removing headlights??
Old Jan 10, 2001 | 04:24 PM
maximumsportZ's Avatar
Lives in a 350Z
I just got some super white bulbs... whats the most easy way to get out the headlight with out messing anything???
Old Jan 10, 2001 | 05:11 PM
Daniel B. Martin's Avatar
Read your Owner's Manual
This topic is covered nicely in your Owner's Manual. Look in the index for "Headlamps, bulb replacement".
Old Jan 10, 2001 | 08:00 PM
metallic97gxe's Avatar
Master Will
you don't.............
take out the whole headlight assembly to replace a bulb just
pop the hood
you will see a black plastic piece turn it either clockwise/counter until it is loose then it will pull out just pop the bulb out off of the wire harness the one by the battery is the easiest the other side lift up the little plastic flap to get to that bulb,be real easy and DO NOT touch the bulb surface with your hands hold it steady by the blackoe socket part and insert real easy.....
LIGHT IT UP! EYES IN THE DARKNESS!
Old Jan 10, 2001 | 08:14 PM
Lives in a 350Z
dan...
well Dan only if I had the manual..
Old Jan 10, 2001 | 08:26 PM
Lives in a 350Z
GTR emblems
anywhere online to purchase those emblems i hear it gives you 10hp !!??
Old Jan 11, 2001 | 02:38 AM
Master Will
Ebay.............
has them every now and then......or try NOPI.com....
I'll see if I can find a site for you to get one/them OK! You can get the real one's which are true metal for like $40.00 or the plastic for like $5.00-$20.00
Old Jan 11, 2001 | 04:13 AM
Rit's Avatar
Rit
I believe Daniel is referring to the Owner's Manual
sitting in your glove compartment. If you don't have one, Call Nissan, and I believe they will send it to you for free. Everyone should read it, at least once.
Old Jan 11, 2001 | 04:57 AM
Re: dan...
The Nissan owner’s manual has valuable model-specific details on the day-to-day use and care of your car, as well as recommended maintenance intervals. If you’ve lost or misplaced your manual, just call 1-800-247-5321 between 8 a.m. and 8 p.m. eastern time, Monday through Friday. There is no charge for 1999, 1998 or 1997 manuals, however, there is a $12.00 charge for owners manuals prior to the 1997 models.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Noela
Sep 26, 2015 08:22 AM
