How to replace Window lift Motor??
Old Feb 26, 2003 | 05:30 PM
fflan513's Avatar
I have a 1996 Maxima; the driver side front window is going up/down very slowly while all other windows perform normally. It seems to me the window lift motor must be going out. What do you guys think? If you concurr that the window lift motor needs to be replaced please give me instructions or point me to the info needed to change it out (hopefully it's not a huge under-taking) . thanks for all your help in advance.
Old Feb 26, 2003 | 05:52 PM
Kashoggio's Avatar
Most likely you need to lube the window track with some sillicone lube.
Just take of the door panel and lube everywhere you see the window having friction
Old Feb 26, 2003 | 05:55 PM
Maxima95Tuner
Re: How to replace Window lift Motor??
Yeah the same sorta thing happened to me not too long ago. Only my problem was the regulator. You will have to pull your door panels off to get to the motor, which is a very time consuming and difficult task. At least it was for me. After you do this, just below your window will be the motor. All I can say about taking the panels off is, there is a screw that needs to come out in the little handle spot.. its covered by a little cap. All you can really do is take your time and pry the door off slowly. I used a flathead screwdriver and it worked fine, it just too a long time.
fflan513's Avatar
Thanks, that would definitely cheaper; I'll try that first. Is taking that door panel off a big pain?
Old Feb 26, 2003 | 05:59 PM
fflan513's Avatar
Re: Re: How to replace Window lift Motor??
Is there an easy way to decide if it is the motor or the regulator that needs repacing? If it's the motor would it be all or nothing? It's been going slowly for several months now. I'm going to try lubing it all up first but still would like to know how to tell the difference between a motor or regulator that is out.
Thanks for your quick responses.
Old Feb 26, 2003 | 06:06 PM
Maxima95Tuner
Re: Re: Re: How to replace Window lift Motor??
If it's the regulator, the window will feel like it isnt connected to anything... like it's just sitting there, both when it's up, and when it's down. I would definately try lubing it up first though, because that could be a problem too.
Old Feb 26, 2003 | 06:20 PM
fflan513's Avatar
Re: Re: Re: Re: How to replace Window lift Motor??
I'll lube it up real good tomorrow if the weather is ok and post back results.
Old Feb 26, 2003 | 06:37 PM
Maxima95Tuner
Re: Re: Re: Re: Re: How to replace Window lift Motor??
Good deal, keep us posted.
Old Feb 26, 2003 | 07:22 PM
fflan513's Avatar
What type silicon lube would you recommend? Something like a thick gel or something like WD-40 spray lube?
Old Feb 26, 2003 | 08:38 PM
Ravq's Avatar
Just FYI
Here is a good procedure for removing the door panel:
http://carstereohelp.com/stereoremovalNisMaxFSpk01.htm
Old Feb 26, 2003 | 08:46 PM
fflan513's Avatar
Re: Just FYI
Excellent photos, thx so much t5his will be very helpful. I love this forum, you guys are the best.
Old Feb 26, 2003 | 08:49 PM
Ravq's Avatar
Get a dry silicone spray (usually looks like a powdery white substance when applied). WD-40 won't work well and will leave a mess.
Old Feb 27, 2003 | 09:28 AM
fflan513's Avatar
window moving well now, thx
Well I took the door panel off and lubricated every area I could reach that the window track up/down on and it's moving up/down faster now. I'm sure glad I didn't take it to the Dealer and let them charge me a king's ransom to replace the lift motor. By the way I lubed it with "White Grease", seems to be really good stuff for this type application. Thanks for all your help guys.
Old Feb 27, 2003 | 10:09 AM
PhaZe's Avatar
Speaking of windows, my 2 REAR windows go down but they won't come up.
the buttons on the door and in the drivers door make the rear 2 windows go down but not up. When I press up on these buttons, I can HEAR the motors work on each side but they just won't move up. What do you guys think it is? I have to ghetto rig it so no one can just push the windows down =(
Old Feb 27, 2003 | 11:12 AM
Maxima95Tuner
Take your door panels off and check your regulators... 90 percent chance that's what it is
Old Feb 27, 2003 | 11:20 AM
fflan513's Avatar
I was told that if the regulator is bad the window will feel loose. The lube job got it moving good now anyway. thx.
Old Feb 27, 2003 | 02:38 PM
PhaZe's Avatar
What is the regulator?
excuse my noobness
Old Feb 27, 2003 | 02:48 PM
Maxima95Tuner
excuse my noobness
The regulator is what connect the motor and the glass together. Like fflan513 said, if the regulator is the problem, the window will feel loose inside the slot. When it goes down, try grabbing it and pulling it up, or just moving it.
Also, fflan513, when I mentioned the regulator, I was talking about PhaZe's problem.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
seesole
Aug 26, 2015 11:22 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
kjm900r
Aug 5, 2015 07:14 AM
