Can someone explaine the premium gas?
Old Feb 27, 2003 | 09:05 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
I have recently purchased Used 99 maxima, I use premium Gas 93 octane. but i don’t know what the pervious owner used. They could of used regular gas. so would that effect my engine? There some engine vibration is that normal, when the car its running normal it’s a little bit of vibration, when I put it in drive it becomes more vibration. I took the car for service, did engine flush, and trainee flush. and did fuel injection cleaning. the transmission its kind of kicks when it changed gears its not smooth like before i changed the transmission oil. Any one with expertise please helps me out. Suggestions, or ideas. Thanks
Old Feb 27, 2003 | 10:21 PM
95emeraldgxe's Avatar
the use of regular gas(87) wont cause that vibration - engine vibration isnt normal for the maxima - could it be your motor mounts??
Old Feb 27, 2003 | 10:59 PM
AssyrianRacer
WHoa!
Theres something wrong here, do what Cystum Tells you, Premium Gas, our engine is really special, as I was reading this i was shoked, The higher the Octane Gas the longer it takes for our car to eat it, but also it needs it for the injectors, the other stuff is crap, this is what I do though, right before the Gas Gauge reaches the 1/4 point, I go put gas again, depending on the grade i had before ill either put High or Medium Octane, so it will kind of ballance out
Old Feb 27, 2003 | 11:19 PM
95maximase's Avatar
Re: WHoa!
That's cool but you must be paying an arm and a leg for premium. I had to give it up. 2.03 for 87 octane here in Orange County, CA
Old Feb 27, 2003 | 11:51 PM
MAX95RUS's Avatar
It's expensive!
How about $2.50 for premium here in SF,CA!
Old Feb 28, 2003 | 12:03 AM
GoldenGlory
Re: Can someone explaine the premium gas?
Originally posted by MAX95RUS
It's expensive!
startin hi-jacking gas trucks!
Old Feb 28, 2003 | 12:40 AM
joaquink's Avatar
¿Hablas Español?
I suggest you do the following:
Replace the PCV
Clean your throttle body
Clean your IACV
There is useful information and howto writeups for all of the above
if you use the search function on this site.
Old Feb 28, 2003 | 06:58 AM
blizz20oma's Avatar
I'm so hood
hehe, that's one of the longest sentences I've read recently
I think the 'balancing out' is more justifying to yourself reasons for not using premium every time. The only 'good' that using a lower octane will provide is on the wallet.
Csytum - just do the normal maintenence items like joaquink suggests...maybe check your plugs (oem? or something like...bosch plugs...) and motor mounts like emeraldgxe said. Might test the knock sensor if you're up to it.
Wow, you guys pay $2.50? I don't feel as bad for the $1.60-1.80 for 92 anymore.
Old Feb 28, 2003 | 07:55 AM
CystumMax's Avatar
Re: Re: Can someone explaine the premium gas?
Replace the PCV
Clean your IACV
Thanks for the help, what is IAVC? at the maxima dealer they did a throttle body for the car. But i dont think they did IAVC can you explaine what that is?
Old Feb 28, 2003 | 07:57 AM
CystumMax's Avatar
Thanks for the help everryone, Appericate it.
Old Feb 28, 2003 | 07:58 AM
maxnewbie's Avatar
Premium gas will get you the better gas mileage period. I've tried midgrade and besides getting some knocking coming from the engine, I also get less mileage. Performance is hindered as well when you go with the lower grade gas. And yes, there is a difference between the gas you buy at a 711 compared to Chevron or Hess (where I by mine). I find that I get more miles on when I buy Chevron or Hess than those other cheap gas places. Test it for yourself and see. Yes, we are paying more for our premium gas, but if we want to continue to enjoy the smoothness and overall horsepower the Maxima has to offer, then we need to feed it well with PREMIUM gas.
Old Feb 28, 2003 | 08:13 AM
FLO_BOY's Avatar
Re: Re: Re: Can someone explaine the premium gas?
It's actually the IACV -- Idle Air Control Valve
Oh, and ALWAYS use premium...do the math...on a full tank, the
extra cost is about $5 a tank...it's TOTALLY worth it...
hope this helps,
FLO_BOY
Old Feb 28, 2003 | 08:16 AM
CystumMax's Avatar
Re: Re: Re: Re: Can someone explaine the premium gas?
hope this helps,
FLO_BOY
Thanks a lot for the help. yeh i will use premium, i see huge difference.
Old Feb 28, 2003 | 08:42 AM
Re: Re: Re: Re: Re: Can someone explaine the premium gas?
roughly 150 dollars more every year for premium gas over 87, not too shabby
Old Feb 28, 2003 | 08:47 AM
CystumMax's Avatar
One other question came to my mind? I was at Kmart this morning, and I saw octane booster, it said on the box its for performance engines. it boost up the octane to 93 or so. can i put regular gas and then put octane booster on top of it. would that work good???
Old Feb 28, 2003 | 08:51 AM
I30tMikeD's Avatar
Re: WHoa!
"Our engine is really special".... is that your scientific explanation.
"It needs it for the injectors".....really, Hmmmm... do you have any idea what your talking about?
Old Feb 28, 2003 | 09:02 AM
Socrates's Avatar
Re: Re: WHoa!
Gotta say, I was wondering the same thing...
Old Feb 28, 2003 | 09:10 AM
dental stud's Avatar
Sure...these guys know exactly what they're talking about.
Cystum want us explaine the speshul gaas for to the pervious owner noo use the reguler. Othurwyse the car will be shoked and it willn't ballance out.
Old Feb 28, 2003 | 09:15 AM
Socrates's Avatar
I done told yih twice now, none o that talk about them devil machines
Them gas stashins iz a trick from the hellfires of satan.. Just pore some water with a little bUhd lite in yer tank.. You'll be goin all day
Old Feb 28, 2003 | 11:16 AM
FLO_BOY's Avatar
JUST BUY PREMIUM AND STOP THINKING ABOUT THE $1 YOU'LL SAVE!!!
seriously...if money is such an issue, perhaps you bought too much car.
-FLO_BOY
Old Feb 28, 2003 | 11:23 AM
1MAX2NV's Avatar
There is no better gas. It's all about the anti knock rating aka octane rating. You just need to use the minimal requirement for your specific engine. ie. VQ30DE can get away with 89 octane but you might get engine knock in hot weather under load. Thus, Nissan recommands 92 Octane or above. If you drive a Honda Civic, you are just wasting your money filling up with 92 octane gas. You won't get any performance gain or mileage gains. Ofcourse if your car is nitrous, turbo or supercharged, then you need higher octanes to fight detonation.
Old Feb 28, 2003 | 11:24 AM
CystumMax's Avatar
-FLO_BOY
Thank you MOM!!!!!
Old Feb 28, 2003 | 11:28 AM
MChapel's Avatar
It'd probablly work, but you'd end up spending the same amount of $$$(if not more), especially with the extra trip to K-Mart and the hassle of adding the stuff to your tank.
Old Feb 28, 2003 | 11:55 PM
GoldenGlory
Old Mar 1, 2003 | 05:25 AM
Zeks 97SE's Avatar
Premium Gas
i paid 1.79 cents in mississippi yesterday, its down from 1.87 last week .. i have been buying less because of the price but there is NO WAY i would put anything other than premium in the chariot ..as for as the vibration..? no idea
gigabyte
Jan 6, 2017 06:05 PM
Fbana41
Aug 29, 2016 12:18 PM
ef9
Oct 4, 2015 08:43 AM
