hot air intake, good or bad?
Old Feb 28, 2003 | 11:09 AM
irishmoyni's Avatar
does any know if a hot air intake is beneficial or am i better off w/ my stock intake
Old Feb 28, 2003 | 11:15 AM
MacGyver265's Avatar
Hot air isn't particularly good for performance, but in the HAI setup, you are able to get more unrestricted airflow, which is good. When you start moving at any reasonable speed, the intake starts taking in colder air, so its not much of a factor then. The only hinderance you'll see when compared to a CAI is from a stop, the CAI will be able to pull fresh cold air, while the HAI has to suck the heated air under the hood. Go ahead and get it, you'll be happy with it.
Old Feb 28, 2003 | 11:17 AM
irishmoyni's Avatar
thanx i was a little nervous
Old Feb 28, 2003 | 11:22 AM
Yeah, I basicly have an HAI setup right now. I bought the Place Racing CAI, but only installed the upper pipe, I'll put on the Cold Air pipe when it starts getting warmer. My car runs fine. The intake does more to make the engine sound better than it does to improve the horsepower. You'll get more performance out of a y-pipe if you don't already have one. The intakes are pretty easy to install too. You can do it in about 30 mins, and at most an hour if you need to follow detailed instructions. The CAI takes longer to install though because it requires cutting some metal and temporarily relocating some fuse and relay boxes.
Old Feb 28, 2003 | 02:51 PM
joew's Avatar
does anyone feel the different with the aftermarket air intake?
Old Mar 1, 2003 | 01:07 PM
bolido2000's Avatar
Besides the sounds, throttle feels a little more responsive at around 3K RPM. Might be my imgagination...
Old Mar 1, 2003 | 03:21 PM
KsuMax's Avatar
Cheesing away...
I like the sound of mine. Didn't have the car long enough before I put on my intake to notice a difference in performance.
Old Mar 1, 2003 | 03:44 PM
mzmtg's Avatar
Minister of Silly Walks
HAI got me .1 sec and 1mph in the 1/4 mile. No lie.
Old Mar 1, 2003 | 06:32 PM
joew's Avatar
what is HAI?
Old Mar 1, 2003 | 06:35 PM
RastaManMax's Avatar
Hot Air intake... Basically a standard POP charger... Open element such as KNN or stillen..
Old Mar 1, 2003 | 06:52 PM
joew's Avatar
thanks.
95Maxi
Aug 29, 2015 09:38 PM
bc992164
Aug 26, 2015 12:19 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
