People with y-pipe i need your help..!
Old Mar 1, 2003 | 09:25 PM
Grey00lustre's Avatar
it's been a week since i install my y-pipe...i love the added power above 2500rpm...but today when crusing around 40-50mph i notice this squeaking or more like ticking sound...i don't think it's the "bees in the can" sound that people complain about..however, when i go above 50mph the sound goes away...any thoughts? also do u guys notice a little vibration on the gas pedals after installing y-pipe?
Old Mar 1, 2003 | 09:36 PM
Nismo's Avatar
does it sound like metal to metal rattling? could be that your ypipe is toughing your "k-member" or that your o2 sensor is rubbing up against some sheet metal under there. go under the car and see if anything like that is happening. yes after ypipe I notice more vibration that I can feel through the steering wheel, pedal, shfter etc. its the resonation that the ypipe makes.
Old Mar 1, 2003 | 09:39 PM
no it's not a metal rubbing metal sound..it's like squeaking sound...i look under my car today and everything seem to be in place...i never had this sound prior to putting my y-pipe..i will take it to shop that install it and have them check it out..
Old Mar 1, 2003 | 09:43 PM
Nismo's Avatar
well then, is it a constant tick? or a whistle sound? alot of pipes have whisting sounds that come from the flex section of the pipe. only thing I can think of is to wrap the flex part with header wrap and see if that makes it go away.
Old Mar 2, 2003 | 07:34 AM
u think it might be the flex section moving or twisting? i heard pepple getting the wrap from warpspeed...
Old Mar 2, 2003 | 11:25 AM
Nismo's Avatar
it doesnt twist it just bends slightly. the exhaust leaks right through the flex thats why the wrap works.
Old Mar 2, 2003 | 11:35 AM
maxspeed96CT's Avatar
The original VQ...
I think its justa cawincidence( spelled worng i know) and something else on you car is messd up
Old Mar 2, 2003 | 02:11 PM
99Maxima5sp's Avatar
Well i dunno about a squeaking sound, but i know i have a very annoying rasp after installing the Y-pipe. It sounds like metal on metal rubbinb but i cant find the source. I even took off my heat sheild. Searched and scoured the pipe and nothin seems to be wrong, im gonna take it off again and maybe put some sealer (silicone or something like that) around all the gaskets to make sure i dont have that air leak sound anymore too. Its especially horrible on cold starts, rasps unbelievably loud. The actual muffler (stock) sounds great though, sounds like i have an aftermarket muffler (nothing loud, just noticeable) Also the gains arent quite there, but i pulled a CEL yesterday and it said my MAF sensor was screwed up, but its cleared now and hasnt come back. Will give it 2 days or so..
However in its defense, under WOT, it sounds great...
Old Mar 3, 2003 | 03:47 PM
thanks for all your suggestion...i will have them check for air leak and also the flex section...the sound i'm getting is more like a hanger moving a making a squeaking sound though...
Old Mar 4, 2003 | 10:24 AM
thanks u guys for all your help..went to the shop today and found what's causing the sqeaking sound...the guy said it was the head shield hitting the cat...he just bent it a little and now no sound except for the nice rumble...
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
Quickywd01
Sep 21, 2016 09:36 PM
REDinLV
Sep 28, 2015 12:31 AM
