Flywheel bolt stuff~~~~~
Old Mar 1, 2003 | 09:38 PM
Nismo's Avatar
quick question- are automatic Torque convertor and 5speed Flywheel bolts the same? The bolts that hold the flywheel/TC to the engine that is. thanks.
Old Mar 2, 2003 | 12:45 AM
Nismo's Avatar
Old Mar 2, 2003 | 12:55 AM
96shogunmax's Avatar
Originally posted by Nismo
I was wondering about this. These bolts are like 3 bucks each new. 8 in all I believe.
Old Mar 2, 2003 | 12:58 AM
mtrai760's Avatar
'Trynna' is not a word
YES! They are EXACTLY the same bolt, do not let the Nissan Parts guy talk you into getting new ones. I already made that mistake when I did my 5spd conversion on my last max. Then, low and behold, I go to swap them and they are the exact same bolt!
Old Mar 2, 2003 | 01:00 AM
Too late!
Old Mar 2, 2003 | 05:10 AM
Cumalittle
they are not the same bolt...the auto tranny flywheel is thinner...thus the bolt is shorter...the manualy flywheel is thicker...thus the bolt is longer...but using the auto bolts will work...how do i knoe??? i had both...
Old Mar 2, 2003 | 11:39 AM
Nismo's Avatar
ok thanks guys. Guess no new bolts for me
Old Mar 2, 2003 | 12:57 PM
JAY25's Avatar
if in fact our flywheel is thicker in my opinion it would be wise to get the new longer ones. But if they are the same exact length dont bother.
Old Mar 2, 2003 | 01:54 PM
Cumalittle
they are not the exact same length...5spd bolts are longer...but auto bolts are long enuff to work...
Old Mar 3, 2003 | 07:59 AM
Stephen Max's Avatar
I'll second that. I used my auto flexplate bolts for the flywheel when I did my tranny swap. Use some Loctite and torque them to spec and they'll do fine.
Old Mar 3, 2003 | 08:07 AM
96BLUMAX's Avatar
Yeah the ones that attach the flywheel to the engine are the same but if you have an aftermarket flywheel you will need to get a few more things.
Old Mar 3, 2003 | 02:05 PM
JAY25's Avatar
what else do you need I dont understand this?
I have a stock flywheel and I am going with a Fidenza alloy flywheel what other stuff will I need?
Old Mar 3, 2003 | 05:14 PM
MardiGrasMax's Avatar
Not that its needed, but some one could send a bolt sample to ARP and I bet they have a bolt in their inventory that matches those.
Old Mar 4, 2003 | 06:39 PM
96BLUMAX's Avatar
Well if you have the stock flywheel you need to take off a disc that is bolted to the middle and put it on the fidanza because it doesnt come with it. This is needed so the sensor on the engine side can read the flywheel speed.
Old Mar 4, 2003 | 11:17 PM
Nismo's Avatar
are you talking about the big sheet metal ring that has little teeth that are all around it? or is there something thats in the middle of the flywheel?
Old Mar 5, 2003 | 11:01 AM
96BLUMAX's Avatar
Its in the middle and mine isnt sheet metal!
Old Mar 5, 2003 | 12:15 PM
Nismo's Avatar
you have a pic of it? I went to the dealer askign about that part and they said it was for the auto TC and not flywheel. Its a metal disc maybe 5" diameter with bolt holes in it- is that what your talking about?
Old Mar 5, 2003 | 04:22 PM
Cumalittle
stock manual flywheel and auto flywheel has that plate...
Old Mar 5, 2003 | 04:41 PM
Nismo's Avatar
Ok great, so that means I can just reuse my auto one and im set. Correct? or do you want to add anythign else?
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
