Shift Lock Button Stuck (4th GEN)
I am having problems with shift lock mechanism on my 95 Maxima. I can start and remove the key fine but the shiftlock button is stuff no matter what. Occassionaly I can get it to release but I can not figure out what exactly pattern.
I tried with brake pedal depressed and tried with out brake pedal depressed. I'm not sure what to look for. I red about the brake light switch but not sure exactly where it is or whether it is the cause.
Anybody with any knowldege of this who can help would be appreciated.
on the front of the brake pedal there are 2 sensors that activate when the brake pedal is stepped on. Im assuming thats what your looking for. they are way up there one is for the brake lights and I think the other is the shift lock mechanism sensor.....I think.
Or one is for ASCD and the other is both brake lamps and shift solenoid combined
Well, that's an alternative. I don't have my FSM or Haynes handy, so can't confirm it. The other possibility is that your shift solenoid (built in to your PRNDL shifter) is sticky.
Originally posted by emanuel
Does any one know if there is a manual way to release the shiftlock button? I cannot get it to release any more.
look in your owners manual. there should be some place that tells you how to do the "manual release"
When you push your brake pedal, do you hear a click coming from your shifter - that's the shift solenoid clicking.
If you don't hear anything, you either have faulty wiring to the solenoid, or the solenoid itself is defective.
I don't believe there is a manual relase **** for 4th gens. Newer Nissans have a small trim slot you can remove to insert a screwdriver and manually release the lock.
You could remove the shifter trim and manually search for the release. I've done it on a Sentra PRNDL, I'm sure it can be done on ours too.
my previous auto max shift solenoid was fukked...when it started acting up...at time i cannot shift into gear...it was just constant stop and restart engine...pressing and releasing break pedal..there was no pattern as to wat worked...but it worked at times...then one day i discover i can shift w/ the brake pedal...strange...ur shift solenoid is fukked...i can even shift into gear when the engine is off w/ no key...
I can't find any thing in the manual about a "manual" release. The section about shiftlock only mentions that if my stop light is not working properly the shiftlock button will lock up. But I checked my brake lights and all three are function normally.
You are right. When I press on the brake pedal, there is no click from the shifter. Any suggestion on how I can troubleshoot the solenoid or wiring?
How do you open the centersole. I have unscrewed every visible screws but the sucker just wont move.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Finkle
Sep 27, 2015 09:53 PM
shaunkey1
Aug 18, 2015 10:09 PM
