which one is lower?......
Old Mar 2, 2003 | 02:11 PM
EZEMaxima's Avatar
Which one of the lowering springs available to the 4th gen is lower in the front compared to the back. I have H&R right now and after installing my subwoofer box and the rest of my car audio/video equipment in the trunk, my front is noticeably higher. I want an even look but i don't want to spend too much on coilovers by JIC and Cattman and i didn't like the annoying noise that was present when i had Ground Controls. Thank guys for the info, by the way i tried searching and it didn't have anything related to the height difference between the front and back of each lowering spring kit.
Old Mar 2, 2003 | 02:50 PM
Bull Jive's Avatar
Re: which one is lower?......
i don't know if there are any springs that are drastically lower in the front than in the back....just get some sprints and call it a day.
Old Mar 2, 2003 | 03:57 PM
njmaxseltd's Avatar
Any car, any spring, unless you have a load leveling system or ajustable coil overs will show added weight in the trunk by making it sit slightly lower.
The remarkable phenomenon is called gravity.
Old Mar 2, 2003 | 04:30 PM
madmax97's Avatar
[b]The remarkable phenomenon is called gravity.[b/]
You would think this would be the case. But i have sprints and i figured with my subs (2 15's in a big *** box w/2 foot amp)it would drop my back end and inturn make the drop even. Yet the front still has finger gap and rear has about 2 finger gap.
Old Mar 3, 2003 | 12:44 AM
geo1317's Avatar
sprint and progress give you a lower drop in the front.
Old Mar 3, 2003 | 12:35 PM
EZEMaxima's Avatar
thanks for the info geo1317
Old Mar 3, 2003 | 12:41 PM
96BLUMAX's Avatar
Yeah my progress did until i got konis in the back and now the back is lower again. But oh well.
Old Mar 3, 2003 | 02:14 PM
1MAX2NV's Avatar
Sprint.
Old Mar 3, 2003 | 02:34 PM
DTR Maxima's Avatar
sprint has a low drop and the front end seems to sit lower, but you should have just cut the springs before installation, but i doubt that anticipated the rear to sag lower
Old Mar 3, 2003 | 11:53 PM
EZEMaxima's Avatar
Just checking for other options other than cutting the springs. I can cut the springs in less than an hour. (remove /cut/ replace)
Old Mar 4, 2003 | 06:10 AM
JAY25's Avatar
get some sprints
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
