Stalling Problem
Old Mar 4, 2003 | 09:52 AM
Canuck's Avatar
Stalling Problem
I am having a stalling problem during start up.
It doesn't happen all of the time but it seems to be more frequent when the engine is cold.
I start the car and the revs jump to 1500 and then they just drop and the car stalls.
If I give the gas a blip the car doesn't stall and seems to run normally.
Anybody have any ideas on what might be wrong?
Old Mar 4, 2003 | 10:51 AM
jbreit's Avatar
if you have an ohm meter and or haynes manual (if you don't have them get one). does it start good when warm? if so, i would suspect the temp sensors....meaning the ecu doesn't realize the engine is cold and doesn't give it enough fuel for cold running....blipping the throttle dumps some extra fuel in.
check:
- engine coolant temp sensor
- iacv
- air temp sensor
clean:
- throttle body
possibly replace:
- plugs
- fuel filter
Old Mar 4, 2003 | 11:25 AM
Canuck's Avatar
check:
- iacv
- air temp sensor
clean:
- throttle body
possibly replace:
- plugs
- fuel filter
The throttle body was just cleaned and the fuel filter and plugs where just recently changed.
I will have to check the temp sensors.
Old Mar 5, 2003 | 09:21 AM
itsgt's Avatar
I have the same exact problem. I too, recently changed plugs, fuel filter and cleaned TB. I have new battery...Went to my mechanic he checked everything out and said everything was fine. So I'm very confused as to why this is happening...and it only happens when its cold outside. Should I ask him to check/recheck if he did already the:
- iacv
- air temp sensor
Old Mar 5, 2003 | 03:09 PM
Canuck's Avatar
- iacv
- air temp sensor
Well atleast I know I am not the only one with this problem. If the car is still kind of warm (but its cold out) I still have the problem. I dont know if this changes things.
Also, Will this affect anything else?
Old Mar 5, 2003 | 03:20 PM
Ookami's Avatar
Having the same problem on my 1998 Maxima SE. Spark plugs were
recently changed (14,000 miles ago) as well as the fuel filter.
The stalling has been unpredictable, but it seems to only occur
during very cold days/nights (below 32F).
Old Mar 5, 2003 | 03:31 PM
Canuck's Avatar
Does it only occur on cold starts?
Mine appears to be only when it is below 45F but I wouldn't know for sure since it has been cold here for a while
Old Mar 5, 2003 | 06:41 PM
Ookami's Avatar
It occurs only on cold starts.
Old Mar 6, 2003 | 11:17 AM
itsgt's Avatar
same here....only when its cold , below like 40F.
Old Mar 6, 2003 | 11:20 AM
Canuck's Avatar
Car was parked at school foran hour and a half and it is abou 50 today and it started like a champ
Old Mar 6, 2003 | 05:25 PM
JiggsHall's Avatar
I've had the same problem for a while now too. I'm going to look into changing the coolant temp sensors.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
