Ignition Coils
Old Mar 5, 2003 | 08:18 AM
Boomer's Avatar
Ignition Coils
How involved is the repair/replacement of the Ignition Coils on a 99 Maxima SE. Just found out all 6 are badddd!!
Thanks.
Old Mar 5, 2003 | 08:24 AM
MrEous's Avatar
^ Jeff™
Easy to do...get a Haynes if you're unsure. It'll come in handy later down the road anyway.
On a side note...didn't the rough idle give it away that something was wrong? I have one coil going out and sometimes the idle will miss a beat...I couldn't imagine how bad it would be with all 6 bad.
Old Mar 5, 2003 | 08:27 AM
supercobraz's Avatar
Haven't had to do it but it would seem there are as simple as changing the spark plugs. Disconnect the 4 screws holding them in and disconnect the harness and pull the coil pack out.
Old Mar 5, 2003 | 08:33 AM
Boomer's Avatar
That's all I get. A slight occasional miss at idle,no hard starting,bad accel.,etc.
I wonder if Dealer is replacing all as a preventive measure or the old Screw job...oops I didn't say that!!
Thanks.
Old Mar 5, 2003 | 08:39 AM
When you say "slight miss at idle" is that idle when in gear with the engine under a strain or when the car is in park. I have a 98, someone said the 98's don't have much of a problem, is that true.
Old Mar 5, 2003 | 08:46 AM
Boomer's Avatar
When sitting at a traffic light I get a slight occasional blip/miss.
Old Mar 5, 2003 | 08:54 AM
Oh hell, that's what I get. You might try changing your plugs I first started getting that problem when I changed to Bosch from the stock NGK's. I continued getting those same symptoms until I changed back to the NGK platinums. Now I don't know if I'm still having the problem or if it's me thinking it's doing it. Whichever it is, it's not anything like before.. I even asked the guy in service at the local dealer and he said had no recollection of needing to change the ignition coils. I had never heard of the problem with the coils until finding this site last week.
Old Mar 5, 2003 | 09:02 AM
Boomer's Avatar
My Check Engine light came on with this problem, which is why Dealer got my 79.95 for diagnosis of bad coils. Search this site and you'll find a lot of problems with coils. Seem to be an epedemic!!!
Little95Max's Avatar
Have you checked you ECU codes? You should get a misfire code. If you have to change them out, it is really easy. The manual on my '95 shows how to change the spark plugs, so you probably don't even need a Haynes manual.
If you need new coils, I have a brand new one I need to sell.
Old Mar 5, 2003 | 09:07 AM
Well I don't get a check engine light so maybe it was just my plugs and now I'm imagining things. Well they're not cheap, but you can install then yourself and save that labor money.
Old Mar 5, 2003 | 09:14 AM
Toolrocks's Avatar
FYI, the dealer usually recommends replacing all 6 coils at once, even if only one is bad. Some people on this board agree and some don't. It's entirely up to you. All 6 gets real expensive. Also, you can check the CEL (check engine light) codes yourself or you can go to most autoparts chain stores and they'll get the codes for you for free. If you decide to install them yourself it's real easy just make sure to hold on to the screws that hold the coils to the valve cover (they're small and hard to get a hold of, make sure you use a magnetic socket/screwdriver). I would shop around to get the best price - try Courtesy Nissan or maybe even a salvage yard. Good luck.
Old Mar 5, 2003 | 12:12 PM
ericdwong's Avatar
F the coils. I have a feeling one is to blame for my lousy idle. I havent gotten around to testing/swapping with another car yet...
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
