How can I get yellow bumper lights to stay on with headlights
Old Mar 6, 2003 | 05:46 AM
maxnewbie's Avatar
I have installed the clear bumper lenses and would like to have the bumper lights (only the sides stay on) to stay on when I turn on my "park" lights, as well as the headlamps. I would also like for them to still blink when I use the turn signal. Is there a way to set this up?
Old Mar 6, 2003 | 05:59 AM
Anachronism's Avatar
I think this as been done but I don't know how. Until someone else comes along - maybe you could wire the power for the parking lights to the ground for the front bumper lights (cut it first). The power wire for the front bumper lights will act like a ground completeing the circut. But when there is power going to that wire (when your turn signal is on) it will no longer act like a ground so your turn signals will still work.
I have done this to my side markers so they blink when the turn signal is on.
Old Mar 6, 2003 | 06:04 AM
BlueBOB's Avatar
get ahold of d_warner on this forum.
He says he's done a right up, but i've never looked and I don't know what he called it.
He gave me a basic run down. He changed the socket from an 1156 bulb socket to an 1157 so that he could power it to always be on and blink. He used the power from the little bulb for the dim lighting and then the power that originally went to the original socket for the blinking power.
Get with him and he'll give you the write up, i'm sure all i'm doing is confusing you, but it looks good.
Old Mar 6, 2003 | 07:59 AM
JacksMax's Avatar
Re: How can I get yellow bumper lights to stay on with headlights
Yup, I did it, then I made this page!! Check it out!
Old Mar 6, 2003 | 08:07 AM
maxnewbie's Avatar
Re: Re: How can I get yellow bumper lights to stay on with headlights
Thanks! Your instructions are excellent!
Old Mar 6, 2003 | 08:26 AM
maxnewbie's Avatar
Re: Re: Re: How can I get yellow bumper lights to stay on with headlights
Does the battery have to be disconnected to do this work?
Old Mar 6, 2003 | 08:29 AM
BlueBOB's Avatar
Re: Re: Re: Re: How can I get yellow bumper lights to stay on with headlights
It would probably be a good idea.
Don't wanna shock yourself
Old Mar 6, 2003 | 08:37 AM
JacksMax's Avatar
Yeah, might be a good idea. I didn't do it, just had the lights turned off. If you do pull the battery for too long, you'll lose the presets on the radio and some things the computer had stored tho.
Old Mar 6, 2003 | 08:40 AM
maxnewbie's Avatar
Re: Re: Re: Re: Re: How can I get yellow bumper lights to stay on with headlights
Yeah, this is what I was trying to avoid.
Old Mar 6, 2003 | 10:32 AM
JacksMax's Avatar
Re: Re: Re: Re: Re: Re: How can I get yellow bumper lights to stay on with headlights
Ah, just keep the lights off while you make the splices. You;ll do fine. Its not brain surgery. You are replacing a single element bulb with a dual. The bright element in the 1157 will now light where and when the old one did, and the power from the sidemarkers will now light the dimmer 2nd one. If you do it right theres no danger of blowing anything. If you run overwattage bulbs anywhere, then this may cause a blown fuse, but from stock it worked great for me. Just mind your splices. Keep tape on all the bare wire, or use an auto parts "splice kit". It'll be fine.
Good luck, EM me if you get stuck or have a problem.
Jack
Old Mar 6, 2003 | 11:07 AM
pearl97's Avatar
Hey, bumps on that write up!!!!! That is the best 'how to' page I have seen. I have wanted to do this mod but was a little hesistant because of lack of detailed instructions. I printed your page and am going to do it this weekend. Thanks again!
Old Mar 6, 2003 | 11:11 AM
d_warner's Avatar
Old Timer
Good job on that page alot easier than what I did. Mine was a little more complicated than yours, but same results.
David
BTW, My write up is is page two of my homepage.
Old Mar 6, 2003 | 11:17 AM
BlueBOB's Avatar
David
what homepage....?
there isn't one listed underneath your handle...
Old Mar 6, 2003 | 11:57 AM
JacksMax's Avatar
Cool! Glad to help! Any questions, or anything, let me know. My Email addy is on the page.
Old Mar 6, 2003 | 02:46 PM
libo74's Avatar
Producto Colombiano
Originally posted by BlueBOB
what homepage....?
look where his sig is suppose to be.
Old Mar 6, 2003 | 04:16 PM
maxspeed96's Avatar
excellent write up jack!! the intructions were very clear. i just did mine and after i was done, i almost made a mess all the lights being on is a big improvement, especially if u have clears.
Old Mar 6, 2003 | 06:15 PM
jkotel's Avatar
that is beyond a doubt one great write-up! makes me wanna try it....
Old Mar 6, 2003 | 09:48 PM
maxspeed96's Avatar
hey guys, Jack has another write up in that link on how to wire your sidemarkers to blink. they blink alternately with the turn signal when the lights are on, and in sync when the lights are off. i did both mods ( turn signal staying on and blinking sidemarkers) and its bad a$$! youre my hero Jack
Old Mar 7, 2003 | 05:37 AM
JacksMax's Avatar
I see
http://images.cardomain.com/installs...84_64_full.jpg
There. Thats not a webpage?
Old Mar 7, 2003 | 06:12 AM
JacksMax's Avatar
Thanks, but I can only take credit for the park lights mod, the side marker one is just a link to another page. I didn't write it.
Thanks, glad it helped!
Jack
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
doobadoo
Aug 15, 2015 06:43 PM
MikesChevelle
Aug 6, 2015 11:36 AM
