having a hell of a time getting my corner lamps out.help!
Old Mar 6, 2003 | 01:35 PM
max99's Avatar
Ok, I'm not dumb and I can follow directions and have done everything on them but I cant get my corner lamps out for anything. I am not sure what I'm exactly looking for that is a ball and socket. I have done everything and tried getting a flat head in every damn spot it will fit. Can someone help or even have a pic of what I'm suppose to be looking for. You think that after 4 years of a good college education I could figure this out!
Max99
Old Mar 6, 2003 | 01:36 PM
A.C.Sanchez's Avatar
Re: having a hell of a time getting my corner lamps out.help!
Max99
Just pull your *** off. That's what I did.
Old Mar 6, 2003 | 01:37 PM
max99's Avatar
I almost did that from frustration but held back when I thought of the money I would be spending to replace a two broken corner lamps.
Max99
Old Mar 6, 2003 | 01:42 PM
funnylittlman's Avatar
Max99
I found if you stick the screwdriver directly on the mount (where the corner lense meets the frame) and then wedge it out a little . . . POP it comes out easier. Just get enough leverage, and be careful not to crack your headlight houseings!
-fnny
Old Mar 6, 2003 | 01:50 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
Max99
spray WD-40 in there first, let it sit for a couple of minutes,then rock it side to side, then wedge the screwdriver in there, and twist.
Old Mar 6, 2003 | 02:14 PM
BlueBOB's Avatar
maybe it was a bad idea, but i took a big wrench and wedged it in there. I found that the larger object I used the easier it came out (i've taken them off a couple times).
Of course, that WD-40 idea is a really good idea. I wish I had thought of that. I didn't break anything, just bent some plastic back there, but nothing that affected anything.
good luck
BlueBOB
Old Mar 6, 2003 | 04:26 PM
MAXIN's Avatar
I have the opposite problem, they wont stay in! If I hit a bump hard enough they pop out the socket!
Old Mar 6, 2003 | 05:03 PM
ReichMax97's Avatar
You talking about the corner lights, or the side marker lens?
Old Mar 6, 2003 | 05:15 PM
sil SE's Avatar
sigh..don't we all have problems with this one. theres about 129487125981623591865912 threads on this
my right side one comes out loose goose, my left one is tight.
the **** just goes into the hole and doesnt want to come back out without a little lubrication.
i should use some wd40 next time. i cracked the end off too. nothing a little crazy glue couldnt fix.
Old Mar 6, 2003 | 05:31 PM
spiff56747's Avatar
you dont need to take out the lens to get to the bulb. if you got small enough hands you can just reach below the back of the lens and pull out the socket that holds the bulb in.
Old Mar 6, 2003 | 08:10 PM
dobiegillis's Avatar
I broke the socket on one of mine changing the bulbs from clear to amber. But superglue seemed to fix it fine. Let's hope I don't have the change the bulbs again...
Old Mar 6, 2003 | 08:36 PM
lefty
Isn't there a screw that holds the corner lamp in place that you loosen from under the hood?
Old Mar 6, 2003 | 08:39 PM
sil SE's Avatar
yes, that would be a funny one to miss though.
Old Mar 6, 2003 | 08:50 PM
Mal5spdMax's Avatar
Hey spiff56747 you know what they say about people with small hands...
Old Mar 6, 2003 | 09:24 PM
MAXIN's Avatar
both L & R corner lamps, next to headlights...... the little socket that holds thats supposed to hold the ball doesn't cut it anymore... I was thinking about glueing as a temp fix, but dont want the same prob this thread starter is having...
Old Mar 7, 2003 | 12:58 AM
spiff56747's Avatar
That they can replace their corner bulbs easily?
Old Mar 7, 2003 | 01:35 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Old Mar 7, 2003 | 02:07 PM
hacim105's Avatar
Yes it is difficult to get them off the first time. But don't worry, it gets easier.
Cotozic
Jun 28, 2017 08:01 PM
03VQMAX
Oct 2, 2016 09:36 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
tnewbs
Aug 28, 2015 10:15 AM
Balkins
Aug 12, 2015 06:39 AM
