Double Exhaust
Old Mar 6, 2003 | 04:18 PM
ZeRo--MaX's Avatar
Double Exhaust
Im gonna buy a Budget Y-Pipe and I want to Put Double exhaust on my max...so do anyone one know if theres some good exhaust system out there to do that???
Old Mar 6, 2003 | 05:22 PM
sil SE's Avatar
Re: Double Exhaust
you mean..duals? did you know theyre out? now theres a setup that will DROPE JAWS
Old Mar 6, 2003 | 05:50 PM
Canuck's Avatar
Re: Double Exhaust
You can buy them from custommaxima.com or have them made locally.
Old Mar 9, 2003 | 03:25 PM
ZeRo--MaX's Avatar
Yeah...Dual...Will It Give More POWER?
Old Mar 9, 2003 | 03:34 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Old Mar 9, 2003 | 03:39 PM
Torgus's Avatar
no. almost definitly not. look sexy tho. and sound sexy too.
Old Mar 9, 2003 | 04:06 PM
95emeraldgxe's Avatar
Re: Double Exhaust
duals - how do you want it..... two mufflers or one muffler with long pipes?
Old Mar 9, 2003 | 04:26 PM
ZeRo--MaX's Avatar
two mufflers...
Old Mar 9, 2003 | 05:26 PM
MIDNightMAX84's Avatar
i dunno about getting much power out of duals, but itll look straight
Old Mar 9, 2003 | 06:16 PM
greenmax95se's Avatar
i think duals would help more if you running a turbo, supercharger, or nos to get the air flow out quiker. But i may be wrong...
Old Mar 9, 2003 | 06:34 PM
AssyrianRacer
Double
The Conventional dual exhaust from custom Maxima is a lot of money, but i got another plan, get a X-pipe instead of the y pipe, this really deos split it into
Old Mar 9, 2003 | 06:48 PM
Craig Mack's Avatar
Re: Double
That's not possible. First, the collectors are verticle to eachother, making a Y-pipe (looks more like an F) the only scenario. Secondly, there's only room under the car for one pipe - a b-pipe.
A Camaro style setup is your best bet. Check my homepage. I used a flowmasters 80-series camaro muffler.
If you want dual fart can's, ahem, I mean mufflers. TheBigSadler banged out his tire well to do dual mufflers. He did a write up on it.
Old Mar 9, 2003 | 06:51 PM
ZeRo--MaX's Avatar
How did you do that?
Old Mar 9, 2003 | 06:56 PM
Craig Mack's Avatar
2.5" b-pipe w/22" glasspack resonator -->flowmasters 80 series (inlet/2 outlets) --> 2.25" pipe wrapping around tire well --> 3.5" x 6" chrome tips. You gotta dremel out the other bumper cutout so be carefull. A muffler shop can duplicate my setup for around $390 minus the tips.
Old Mar 9, 2003 | 07:15 PM
2maximas's Avatar
Re: Re: Double
Could you do a writeup on how you did yours? I am very familiar with the Camaro style muffler having owned several Camaros. just a sketch of how it was layed out under the car would be enough. I'd love to have duals on my Max,(I saw the example where the guy beat the hell out of the spare tire well and that is not something I want to do) buy the way do you get the same through put on both pipes or does one flow more than the other? Any droning with the muffler at certian RPM's?
2Maximas
Old Mar 9, 2003 | 10:39 PM
thebigsadler's Avatar
Re: Re: Re: Double
Old Mar 9, 2003 | 10:47 PM
fierostetz's Avatar
thebigsadler-
prepare for liftoff!!! those pipes are a tad excessive-
a dual layout would be more efficient if the max had a longitudal engine layout, as opposed to a transverse- any gains you got would be negated by the added weight, you might as well glue an extra pipe on one side of your bumper.. the max doesnt have too much of an exhaust flow issue, putting on a free flow muffler doesnt do too much... possibly a true dual exhaust with shorty style headers, and an x pipe... i really don't think it would be worth the effort, the max is actually pretty well designed, after getting rid of the stock y pipe...
Old Mar 9, 2003 | 10:55 PM
CaLSoNiC
Originally posted by fierostetz
thebigsadler-
If you hadn't noticed. I think he was going for looks more than speed. Why else would you slam your car to the ground a bling bling it all day =/
Anyway. He has one of the nicest maximas Ive seen. but he needs a 5-speed.
Old Mar 10, 2003 | 12:31 AM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
but.....how does it sound?
Old Mar 10, 2003 | 01:42 AM
Quack 2x's Avatar
This might be another way to get a functional dual exhaust without damaging or removing the spare tire well. I was looking at the Borla catalog, and they showed a muffler for F bodies that had a "Y" in the pipe leading in to the muffler (like an exhaust cutout, for you older folks that remember these things).
Anyway, they have plates that fit into the flange with holes of varying diameters, ostensibly to vary the backpressure (and noise) by diverting some of the exhaust flow and bypassing the muffler.
Instead of mounting it transversely, like on the F-body, perhaps it could be mounted f/r and the "Y" pipe before the muffler routed around the spare tire well. You would get the dual exhaust look, but not the "dual muffler" look.
This would probably take some engineering and pipe-bending skills, but probably wouldn't result in as much "modification" to the undercarriage and floorpan.
Aloha,
Quack2x
Old Mar 10, 2003 | 04:17 AM
Kashoggio's Avatar
duals suck
Justin Kroll
Oct 1, 2015 07:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
