just got back from the dealer (starting problem)
Old Mar 7, 2003 | 03:46 PM
RI-Max's Avatar
i had a starting problem just cranks but would fire up after awhile.
today it didn't wanna start . so i brought it 2 the dealer and they told me its the ignition switch. so they replace it cost me 210.00 parts&labor. they said i have anythere problem idle ruff $ starting problem still but no as bad they said. so they said they gonna check for a bad ground 2morrow.
my problem i have:
starting problem
whitling noise on idle
Old Mar 7, 2003 | 04:37 PM
ßaller's Avatar
Re: just got back from the dealer (starting problem)
my problem i have:
starting problem
It sounds to me like your stater, but maybe it is all part of the ignition swith, somebody correct me please. I had my starter replaced because of similar issue a couple years ago and had it fixed for about $150 with a replacement starter. Good luck mang.
- ßaller
Old Mar 7, 2003 | 04:43 PM
Conrad283's Avatar
I need a truck
Re: Re: just got back from the dealer (starting problem)
whistling while idling is caused my loose belts (get that checked out) and the starting problem ... try getting the car jumped, if it doesn't work then it's the starter, if it does start then it's the alternator
Old Mar 7, 2003 | 06:54 PM
RI-Max's Avatar
oo well i'll keep u yous posted thanx
Old Mar 9, 2003 | 03:24 PM
MAXSLUT's Avatar
That's what you get for buying a maxima j/k you'll be fine
Old Mar 9, 2003 | 03:26 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
No its not the maxima. any car could have same problems...
Old Mar 9, 2003 | 03:28 PM
CystumMax's Avatar
Originally posted by CystumMax
No its not the maxima. any car could have the same problems...
maxinout93
Aug 20, 2015 02:17 AM
Mcnabb34
Aug 11, 2015 08:45 PM
kirkhilles
Aug 8, 2015 10:53 AM
Gsantos79
Aug 8, 2015 07:41 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
