ECU daignose: 0707 + 0304... need help!
Old Mar 9, 2003 | 01:02 PM
happyricefob's Avatar
V^___^V
aite so i did a ECU decode and i got 0707 (Rear Heated O2 sensor) + 0304 (knock sensor)... should i change them? i haven't been doin any agressive driving lately, is it essential to change it? where can i get quality and cheap parts from? cuz i don't wanna go to the dealership... please help me.
Old Mar 9, 2003 | 01:04 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: ECU daignose: 0707 + 0304... need help!
change your knock sensor, but your o2 sensor take out and clean it with some gasoline. and put it back in usally it works. whats your cal milege.
Old Mar 9, 2003 | 01:08 PM
V^___^V
Re: Re: ECU daignose: 0707 + 0304... need help!
where can i get cheap and quality knock sensor besides from the dealership?
Sin's Avatar
Sin
GASOLINE?!?!?! Actually, it's brake cleaner. And it's also a good idea to use a butane/propane torch as part of the cleaning process. And this will only solve the O2 sensor problem IF it is malfunctioning because of contamination (which is common), and not if the sensor itself has failed.
Also, what a lot of experienced Maxima owners have noticed is that the knock sensor code usually doesn't mean the knock sensor has failed. I believe they call it a shadow code or something like that. Try cleaning the O2 sensor first, reset code. See if the CES light comes on again.
Old Mar 9, 2003 | 02:19 PM
1996blackmax's Avatar
Re: Re: Re: ECU daignose: 0707 + 0304... need help!
I bought mine from expressautoparts.com last month for $107.xx shipped. If you clean out your 02 sensor and you still have a KS code then I suggest you get it from them. They are the cheapest I found. The only code I pulled was 0304, even after resetting my ecu several times. So I just went ahead and bought it, car feels better now. No more codes. One thing, when I was looking at my stock sensor(had small cracks on it) and the new Bosch sensor, they looked identical. Every #, word, and marking are the same. I know some of our oem sensors are Bosch, maybe this one is too.
Old Mar 9, 2003 | 02:51 PM
deezo's Avatar
http://forums.maxima.org/showthread.php?threadid=104931
Old Mar 9, 2003 | 05:37 PM
V^___^V
did tat, done tat... jus need help on fixing it.
Old Mar 9, 2003 | 05:41 PM
iansw's Avatar
From my limited experience, you should clean the O2 sensor, then replace if necessary.
If you get the 0304 code by itself is the only time you should replace the KS. Most likely when you get the O2 sensor repaired, the 0304 code will dissapear at the same time.
If you lose the O2 code and STILL get the 0304, then replace the KS.
But a KS Code with an O2 code probably means only the O2 sensor is bad, not the KS.
Old Mar 9, 2003 | 05:56 PM
V^___^V
hey.. thx for the detail info on this, appreciated =)
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
