Stillen Kit: 3M Tape and Rivets and Screws
Old Mar 9, 2003 | 04:46 PM
ZeRo MaX's Avatar
I'm installing my Body kit soon... just wanted to know the specs on installations...
What size 3M tape do I need and where do I put it on? (how wide does it need to be?)
Where do the rivets go?
How many screws should I screw on and where?
Thanx!
Old Mar 9, 2003 | 05:27 PM
metallic97gxe's Avatar
Master Will
the kit came w/the tape did it not? use the tape along the front and sides..use screws in the fenders and rivets in the front if you look close at these pics you can see mine...
http://www.nissanx.net/gall/alb/Pics-Mods/DCP_0076.jpg
http://www.nissanx.net/gall/alb/Pics-Mods/DCP_0080.jpg
here is my how-to for the Ionic Dynamics body
http://maxima.cardomain.com/member_p...d=24211&page=9
Old Mar 9, 2003 | 06:10 PM
redmaxpa007's Avatar
i SeE what you did therE
we are not using any rivits
tape and screws only.. and i have smoe tape..
Old Mar 9, 2003 | 06:44 PM
erty67's Avatar
Decal Specialist
NOOOO.....I don't suggest using the white tape that comes with the kit. Every area that i used that tape came undone. Use 3M tape. It holds up much better.
Old Mar 9, 2003 | 07:16 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Guys,
I used Rivets to put in my side skirts. Well, they've always caught in the door every now and then, no big deal really. But now I've noticed that some of the screws are getting close to rip outta the skirt! And the damn skirt has been getting caught up in my door, making everything worse.
What do I do.
Old Mar 9, 2003 | 07:19 PM
MaximaRider's Avatar
4Th Gen Stillen Kit only requires screws...
Front Lip: 3 screws, 1 in the middle front, 2 on each side in the fender well
Side Skirts: 5-6 screws all along and into the wells if u can get them there.
Rear Skirts: all underneath about 4-5 screws for each rear skirt
I am positive my kit will NEVER fall off and its the flushest looking kit i've seen aside from others on the board, because i have seen kits that look warped because of the rivits.
-Arnaud
P.S. im ****ed
Old Mar 9, 2003 | 07:21 PM
Originally posted by Craig Mack
Guys,
What do I do.
are you talking about the screws in teh ends of the side skirt?
just remove the old scres and redrill them in a different location. (might look poopy, but it will fix your problem.. and use some washers next time
and use 3m 2 sided tape (OEM MOLDING approved) on the side skirts middle sections..
Old Mar 9, 2003 | 07:23 PM
-Arnaud
P.S. im ****ed
i used 2 screws in the front. one on each side and tape in the middle
side i sused one screw in each end and tape in the middle and the rear..
i screwed the hell out of them...
Old Mar 9, 2003 | 08:16 PM
Ramius83
I don't know about you all, but even without using the 3M Tape on the top of the side skirts, my damn doors still shut on the side-skirt. And, considering that the body-kit pieces are black underneath, and my car is white, it doesn't look to good? Anyone have a fix????
Old Mar 9, 2003 | 08:30 PM
erty67's Avatar
Decal Specialist
I grinded down the inside(bottom side) of the section that the door hits with a Dremel. This made the skirt thinner in that area. The door stopped scraping, but be careful you don't grind through it.
Old Mar 9, 2003 | 08:44 PM
Ramius83
Well, its funny that you say that because after the first time I had the kit painted and it was hitting then, I sanded down the top portion of the side skirts to prevent this lol. The driver's side is doing pretty well, but the right side is horrible. Oh well, when I have the front bumper, front spoiler, and rear spoiler re-painted, I will have them do the side skirt again......
Old Mar 9, 2003 | 08:52 PM
erty67's Avatar
Decal Specialist
That's the + side of grinding the bottom....no need to repaint it! It will be hidden
Old Mar 9, 2003 | 09:35 PM
krbga's Avatar
If you want it really SOLID on there...
use the GRAY 3M tape that holds up to 5lbs. Front Lip
The one that everyone uses is the white 2lb 3M tape.
Old Mar 10, 2003 | 07:00 AM
ZeRo MaX's Avatar
ok... no rivits...
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
doctorpullit
Mar 29, 2016 11:08 AM
Nv2dmaxmd
Oct 19, 2015 05:37 PM
sliptap
Sep 30, 2015 05:57 AM
