Corroded battery terminals
Old Jan 12, 2001 | 04:52 PM
dch95's Avatar
If my terminals keep on getting corroded, is there a problem with the electrical system or is this normal. I bought some of those red and green felt washers to install but I,m wondering if this is only a "band-aid" fix or if it is OK. TYIA
Old Jan 12, 2001 | 07:32 PM
shane's Avatar
you can wash it with baking soda and that will take care of the corrision and can use 2 way tape and 2 pennies near the terminals and that may help keep the acid off of them,also theirs some spray you can buy for that too
Old Jan 13, 2001 | 03:27 AM
Kenneth's Avatar
OG :)
remove the terminals, clean using pepsi then use baking soda and rinse
Old Jan 13, 2001 | 03:37 AM
BSwithTF's Avatar
Grease works, not pretty or very clean though.
I work at a diesel shop and we always coat the terminals with a thick grease after we put them back on. Supposed to seal out any water or contaminants. It's kinda messy though if you have to take them off soon after for some reason. Seems to do the trick though. If water gets there, you can get electrolosis between the battery and the cable which equals a bad connection.
Old Jan 13, 2001 | 06:36 AM
dch95's Avatar
Grease, Pepsi and Pennies
Thanks for all of your inputs. I appreciate your time and I will see what I can do with your ideas.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
