Re: Grinding....Bearing Problem?
I was going around a curve in my apartment complex and heard a grinding coming from the passenger side front of the car. This is my question could this be the wheel bearings going bad. This is my reasoning:
1. When I was going around the curve I was not accelerating and had my foot on the clutch. I wasn't braking either.
2. I haven't had any whining or any other problems when accelerating. So, I don't think it is the differential bearings.
3. This it has done it twice now and both times it was after the car had been sitting. The first time about a 3 hour timespan and the second overnight ~ 12hours.
So what do you guys think? I really hope it is not the differential bearings and just a wheel bearing problem. This is the second problem within about a week!
I would suggest checking torque on the wheel studs first...if one is a bit loose it can tension up on turns and create friction/noise.
I just went thru and replaced all the front wheel bearings and seals and it still did not fix my problem.
Originally posted by MaximaMoJo
I am going to check this when I get home. Would it make this sound even if I wasn't braking at the time?
I think it might be the brake wear indicator. It is like nails on a chalk board for only 5 seconds at the most. It isn't real loud, I had to turn the radio off to hear it better. I will keep you guys updated.
It also could simply be that your aluminum plate behind the hub is rubbing - I had the same problem at one time, and it would only make the noise on turns.
Just bend it slightly back with your hands.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
