How do i adjust the headlights?
Old Mar 13, 2003 | 10:33 AM
teeezmaxSE's Avatar
Since the search button is no longer usable,
can you tell me how to reaim the headlights?
I played with the two long screws behind the headlights but it doens't seem to have done anything..
Thanks in advance!
Old Mar 13, 2003 | 03:47 PM
tzmanles's Avatar
Re: How do i adjust the headlights?
Thanks in advance!
How do I reaim my headlights / foglights?
The adjustment bolt closer to the parking/corner lights (outboard of the vehicle) is for the up/down aiming of the headlamp. The one further inboard is to control the right/left aiming of the lamp. You'll need a 10mm wrench to perform the aiming task.
To do the height adjustment, park your car so that the headlamp lens faces are about 25 feet from a wall. This wall should be perpendicular to the ground and level in all aspects. Measure the distance from the center of your headlamps to the ground. Mark this dimension on the wall. From this mark, move down 3.75" to 4" and make another mark. Begin to turn the adjustment bolt so that the centers of your low beam patterns land on that second mark that you made. As for your right to left adjustment, mark the centers vertically and aim so that they point straight out. Bear in mind that sometimes adjusting the right/left bolt can change the setting of the height adjustment slightly.
By the way, the foglamps can be aimed the same way. The foglights are 8mm.
Credit: Albertt and j-95G (for the foglamp info)
Two really good articles on aiming of headlights and auxiliary lights:
http://www.autooptiks.com/aiming.html
http://lighting.mbz.org/tech/aim/
Old Mar 13, 2003 | 03:50 PM
clee130's Avatar
Re: Re: How do i adjust the headlights?
Originally posted by tzmanles
*snip*
Which can all be found in the thread titled "4th gen FAQs (READ ME! PLEASE! READ ME!)" at the top of the forum.
tarun900
19
Dec 20, 2021 06:57 PM
doctorpullit
Oct 28, 2019 10:58 PM
leatherneck
Sep 30, 2015 09:16 PM
Noela
Sep 26, 2015 08:22 AM
