Need help fixing CEL codes - 0705 0903
Old Mar 14, 2003 | 03:13 PM
BBaker025's Avatar
After I installed my VI I got 2 CEL codes can anyone tell me how to fix them?
The Codes are:
0903- EVAP canister vent control valve circuit fault
0705- EVAP system leak
Thanks alot
-Brian
Old Mar 14, 2003 | 04:51 PM
BBaker025's Avatar
Old Mar 14, 2003 | 06:20 PM
jvienneau's Avatar
The evaporative canister collects fumes from your gas tank and then "purges" them into the intake when you start the engine. Your codes could just be a loose gas cap as that causes a leak to be detected.
Old Mar 14, 2003 | 08:50 PM
pMB's Avatar
pMB
loose gas cap, or evap canister purge valve stuck.
just behind rear driver's side wheel, you'll see a black plastic box. That's evap canister. take it out and shake it.
if there's some water-ish substance, turn it upside down and let the water out.
If the valve is stuck, you have to clean it and put it back.
Old Mar 14, 2003 | 08:51 PM
BBaker025's Avatar
how do u clean the valve if it is stuck?
Old Mar 14, 2003 | 08:59 PM
pMB's Avatar
pMB
mind you, I have one of the first 4th gens (made in 94!)
mine was like those of the 3rd genners... right beneath the brake master cylinder.
I cut the glue that was holding the valve cover, then opened the whole thing with a screw (-) driver.
But you can just clean the valve by putting air through the hose connected to it, like blowing with your mouth (hmm, the good old way) or compressed air.
Old Mar 14, 2003 | 09:13 PM
BBaker025's Avatar
ill give it a shot tommerow and see how it goes, thanks alot!
Mar 12, 2020 12:06 AM
homeofbacon
Sep 23, 2015 07:17 PM
220k+ A32
Sep 22, 2015 03:08 PM
JoshG
51
Sep 21, 2015 10:41 PM
Steven Orozco
Sep 12, 2015 10:41 PM
