Losing braking at higher speeds
When I'm going highway speeds, I go to use the brakes and they feel
like they're slipping. Not very tight like they were. My brakes are
stock and I just swapped all four pads like a year ago.
Could they need to be done again. I can't really tell.
J.
J.
What kind of pads did you use?
Was the system bleed after you put the pads in or better yet when was the last time you changed your brake fluid? Your brake system should be flushed with clean fresh fluid from time to time. I like to do it when I change the pads.
James92SE
142
01-02-2024 09:23 AM
