Setting Timing
Old Mar 17, 2003 | 02:58 PM
maxxed out's Avatar
Setting Timing
Does anyone have information on how to set the timing correctly for a 96 nissan maxima? I was changing the water pump and the timing chain moved. I'm not sure if it is out of time. The Chilton/Haynes manuals describe how to set the timing. Two problems I'm having are that 1. the chain wasn't marked for reference and 2. I can't find the two links that are "darker"(as described in the Haynes guide) than the other links to line up with the camshaft sprockets. If anyone has any tips/suggestions I'd greatly appreciate the help. Thanks
Old Mar 17, 2003 | 05:07 PM
delio's Avatar
PM mardigrasmax
Old Mar 17, 2003 | 06:39 PM
wgoogs's Avatar
did you have to remove the engine like it says in the Haynes manual? I want to check my timing but I have no way to remove the engine
Old Mar 17, 2003 | 06:46 PM
Dev's Avatar
Dev
i didn't know 4th gens timing could be changed....
is there a way to advance timing???
i have a 99 limited
Old Aug 19, 2014 | 06:38 AM
MarineDad's Avatar
Timing chain/Water pump - UGH!
I had the same problem... including pulling threads when putting the new water pump back in, and then a horrendous chain rattling noise once i got the car started back up again... we supsected the timing chain had moved and the time was off, but then i read, after getting everything taken off the car to take the timing chain cover off... that the rattling sound was normal and would go way after the car ran for a few minutes... we have identified the marker links on the main timing chain... and the marks on the gears... but i can't find any information stating what the proper position is for the markers or how to adjust the cam shafts if needed... first question... is the rattling normal and i can just put everything back together? Second question - does somebody have information about getting the cam shafts lined up correctly... YouTube University has been somewhat helpful, but lacking some key answers...
Old Aug 19, 2014 | 07:32 AM
dwapenyi's Avatar
Why use haynes when you can get the Nissan factory service manual?
http://www.boredmder.com/FSMs/Nissan/Maxima/
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
