does a car look dumb if i dont lower it?
I have a black 99 gle and i really am too lazy to lower it...if i put 18" rims on it (I am fully aware that it will raise the car 1") will it look dumb all around?
Re: does a car look dumb if i dont lower it?
J/K
It depend on you. To me it will because I HATE wheelgap and you will have alot of wheelgap (maybe about 4-5 inches ) if you don't. If you can afford to just lower it. You will LOVE the results
IF YOUR GOING TO THROW 18"s DEFINETLY DROP IT 1 1/2" TO 2". MORE THAN 2" WOULD LOOK EVEN BETTER BUT YOUR GOING TO SCRAPE ALOT AND YOUR WHEEL WELL MIGHT INTERFERE WITH YOUR TIRES. ALSO IF YOU DON'T WANT TO LOOSE ANY PERFORMANCE GET SOME LOGHTWEIGHT RIMS(15-22LBS).
NO!
it depends on you if you ask on here "they" all will say yes it will but then again it's your car.....do what you want
and in the end it is a matter of opinion.......
here at Maxima.org don't ask or post unless you want negative posts about this or that trust me I know....and when you post or ask, you are setting yourself up for whatever they throw out, so be prepared....from me to you!!!!!!!!!!!
On a related note..
18in rims will raise a car obviously but what size tires would be able to offset the larger rim size as not to raise the car at all?
I have maxspeeds and the way my car sits now is perfect. I was planning on 18's but if it's gonna raise my car another inch..hmmm
Yes, it will look stupid.
As William said, it's really a matter of taste. I think aftermarket rims win rubber-band tires look silly with a non-lowered max: it hilights the wheel gap. Mine is not lowered (yet), but my tires are a little bigger so I think it helps. From some angles it looks perfectly fine, while at other angles it does look like a 4x4. I'll lower mine when I get some rims.
Originally posted by BOZOnPJs
lowered kicks a$$ in the summer, not lowered kicks a$$ in the winter.
Sometimes my front lip picks up snow from piles where driveways were plowed into the road.
please lower your car if you put wheels on it.. i mean really, a set of sprint springs are like $120, and keep a decent ride until you can afford some nice struts.. or use h&r or eibachs..
driving around with wheels and no drop is
except in william's case because he is so dead bent against it..
Re: NO!
No
Do what you want and what you like. Dont place looks before your needs. I wouldn't mind a small drop with mine, but where I live, and all the roads and miles I drive, a drop is simply impracticle. Almost stupid. Just weigh your needs and what your car needs to do for you, and then make your own decision.
Originally posted by erty67
Will, you must have the best looking maxima with the least respect! It's usually a newbie post too
yes I'm used to the negative comments on my car from this site..it's normal...
so........
Re: if you have a SE
Originally posted by darrick
mabe you can get away with it but not on gle or gxe nasty wheelgap will get 2 you
eh, Im pretty sure the ride height is the same regardless of trim package. The SE might ride a bit more firmly but it doesn't look any lower than a GLE or GXE. If in fact it is a bit lower the difference is negligable. Personally I couldn't stand the look of my car on 17s before I lowered it. IMO it really looks ghetto to just slap on some rims, its the little things that make a car look nice, especially when the said car comes with a wheel gap looking like a sedan/suv hybrid.
If you want to keep an awsome ride, but add amazing handling and performance you really don't need to lower it.
KYB AGX's
Addco Rear Sway Bar
Front Strut Tower Brace
Some nice sticky 17 inch wheels-n-tires
Keep it spotless & black out the wheel wells and you wind up with something like this.
KYB AGX's
Addco Rear Sway Bar
KYB AGX's
Addco Rear Sway Bar
KYB AGX's
Addco Rear Sway Bar
Yes very good example, you'll like you're ready to go offroading but with the wrong tires.
The distance from the center to the end of the tire is the same if u have 16's or 18's if u stay with in proportion with rimsize to tire thickness. like: 215/50/16 & 215/40/18 will be the same size and won't raise or lower your car last time i checked.
correct me if im wrong.
Re: Re: does a car look dumb if i dont lower it?
Originally posted by itsgt
since when does changing wheels....in this example stock to 18's raise the car??
Along the same lines..
People say a larger wheel will also decrese the gap between the tire and fender. If you stay proporational with the tires and wheel with 18's as compared to 16's wouldnt the gap be exactly the same?
Lakersallday24
Jun 16, 2019 01:35 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
