Front coil ohms??
Front coil ohms??
I just checked the ohm readings on the front three coils. With the digital multimeter set at 20k on the ohm side I got the following readings from left to right
1.87 OHms Cyl 1
1.68 Ohms Cyl 2
1.86 Ohms Cyl 3
Since my problem comes and go and now that its really damp it seems to be more apparent. I'm wondering if number two right there may be going out. Thanks for the input I'll check the other three in the back tomorrow.
1.87 OHms Cyl 1
1.68 Ohms Cyl 2
1.86 Ohms Cyl 3
A lower reading is better than a higher reading when checking for continuity, so your #2 coil is actually performing slightly better than the other two. The values are pretty consistent, so check the remaining 3 coils on the rear bank & get back to us.
I don't see a problem so far.
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
