CEL cant fix please help
Old Mar 19, 2003 | 08:24 AM
brianbrannon's Avatar
95 with code for primary ignition fault
#2 and #3 coils dont fire
unless I disconnect the front crank sensor
Ohmed all the wires replaced the sensors
Old Mar 19, 2003 | 08:30 AM
njmaxseltd's Avatar
I didn't think the car would even start with a crank sensor disconnected?
Old Mar 19, 2003 | 08:37 AM
GoldMax99's Avatar
I read on the internet that another probable cause for misfiring is that the timing chain is not lined up properly. Have you done any work to the car recently that might affect the chain. I.e. When you change the water pump you have to remove the chain and sometimes it gets put back on misaligned. If I run into the link to this article I'll post it here.
Old Mar 19, 2003 | 08:38 AM
GoldMax99's Avatar
Well what do you know...I found it:
http://www.asashop.org/autoinc/jan2001/techtips.cfm
Old Mar 19, 2003 | 10:46 AM
njmaxseltd's Avatar
WOW - The newbie saves the day!
Old Mar 19, 2003 | 11:29 AM
PedalKick's Avatar
I was trying to imagine how this could occur as the timing chain is not taken off of the crank sprocket or the cam sprockets, but I think I know. The FSM says to rotate the crank backwards to loosen the chain on the WP sprocket and hold the chain out of the way when you extract the WP. If you let go of the chain with the WP out, the chain may be slack enough to fall off the crank sprocket. When you pull the chain out of the way again to clear the WP as you install it, the chain may engage the crank sprocket on another tooth. Definately something to look out for when doing the WP.
jmlee44
Oct 2, 2022 02:13 PM
D Mason
Jun 21, 2016 04:43 AM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
