Nissan antifreeze
Nissan antifreeze
Alright. I know that we need phosphate free and silicone free ethylene glycol right. Now why does Nissan antifreeze cost 15-18 dollars. The Nissan parts rep told me that if you mix nissan and gm antifreeze, it'll eat up your engine. I was thinking about using some o'reilly $8 stuff.
By the way, can somebody post me a link to show me a pic for the antifreeze plugs on the engine block? Thanks.
The way many do it (including myself) is to do many drain/fills on the radiator. Removing the engine plugs is pretty difficult.
I also use Toyota Red Coolant since it's designed for extended drain intervals. I run it ~2 years. I think I paid $10 a gallon.
-hype
-hype
Originally posted by SamMan23
can anybody confirm or not confirm what the dealer guy said?
Check out this link for a more detail discussion on the subject.
http://forums.maxima.org/showthread....hreadid=115914
White96MaxSE
Originally posted by White96MaxSE
Yes, It is true that the GM (Long Life) antifreeze should not be mixed with ethylene glycol antifreeze and that would probably include Nissan's OEM antifreeze. In the long run I believe it will damage your engine.
White96MaxSE
White96MaxSE
Thanks Whitemax. I appreciate the help
03-12-2020 12:06 AM
