Another spring question...
Old Mar 20, 2003 | 05:57 AM
shaz's Avatar
Its tough to find info these days w/o the search feature...anyways, I'm finally putting on my 18's next week and I need to lower my car. Cant afford struts right now so I just want to run some springs on my stock struts for a few months. Im trying to get a relatively close to stock ride that looks even on my 98 5spd. Any suggestions? I was thinking H&R, B+G, or Maxspeed. Which would ride the best on stock struts? Thanks
shaz
Old Mar 20, 2003 | 06:26 AM
erty67's Avatar
Decal Specialist
Re: Another spring question...
shaz
I don't think any lowering spring will work better with stock struts than another. Any spring you get, the struts will probably end up blowing out. Personally, I would try to wait a little longer and do the struts at the same time. Otherwise, you'll be doing twice the work.
Old Mar 20, 2003 | 05:42 PM
shaz's Avatar
come on someone...anyone put maxspeeds over stock struts?
shaz
Old Mar 20, 2003 | 06:45 PM
XXXL Cracker's Avatar
Some people have... it is not like you will lose your struts in a week.
It is just more convenient to do them all at once.
The OEM struts and springs are designed to work together. Lowering springs will put more stress on your stockers.
D
Old Mar 20, 2003 | 07:04 PM
PedalKick's Avatar
Yessss...
Check the drop on my homepage. They are working great so far.
Installed one month ago on 95 SE 5sp with 60k miles.
shaz
Old Mar 21, 2003 | 04:55 AM
shaz's Avatar
Originally posted by PedalKick
Yessss...
Hows the ride quality?? stiff? soft??
shaz
Old Mar 21, 2003 | 05:13 AM
Dev's Avatar
Dev
shaz
for stock struts...h&r's are probably the best for ride/less damage to shocks than others from the smaller drop.
b+g seems to hang low at the rear, im going with progress, which is a bit lower at the front...i think that gives it a more aggressive stance.
Old Mar 21, 2003 | 07:50 AM
PedalKick's Avatar
shaz
Very little difference from the stock ride. Perhaps slightly firmer now. I'm happy with the MaxSpeeds. It got rid of the 4x4 look but did not compromise ground clearance while preserving the original ride quality. I'll keep an eye on the shock/struts for evidence of leaks and wear but I don't expect any problems.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
