EVAP ecu codes
Old Mar 21, 2003 | 05:37 AM
DSimple1's Avatar
EVAP ecu codes
After getting my oil changed the good ole service engine soon light came on. After pulling the codes and looking them up, its saying there are problems with the EVAP Canister vent control valve and the EVAP Control System. What is the best route to take to troubleshoot this?
Old Mar 21, 2003 | 05:43 AM
njmaxseltd's Avatar
Look behind your drivers side rear tire. You'll see a canister, some hoses and a valve with an electrical connection plugged into it. Take that valve out, take it apart and clean it up. Make sure all the moving parts inside are free. WD-40 works well for this. Check the coil with an Ohm meter to make sure it's ok and put it back into service.
That valve is in a nasty spot and is subject to a lot of grime and moisture which usually plug it up.
Good luck!
Old Mar 21, 2003 | 06:06 AM
DSimple1's Avatar
Good luck!
Right on! thanks for the info and the quick response. One more question, my car is due for emissions testing this month, if I didnt get the evap problem fixed right away, would it cause any problems so that the car wouldnt pass?
Old Mar 21, 2003 | 07:04 AM
PhillyMAx's Avatar
Re: EVAP ecu codes
From what I understand, this will not affect driving performance or cause any damage to your engine. That light is annoying though. I just tried cleaning mine not too long ago, but the CEL has come back on even after a few resets, so I ordered a new canister and evap valve from the dealer and will pick it up tomorrow.
Old Mar 21, 2003 | 07:16 AM
DSimple1's Avatar
Re: Re: EVAP ecu codes
How much does a new canister and evap valve cost?
Old Mar 21, 2003 | 07:34 AM
PhillyMAx's Avatar
Re: Re: Re: EVAP ecu codes
It'll run you anywhere between $80-$100 for both , depending on dealer mark-up. The dealer had to order my canister, so the total for me was around $110. I have a Cali emissions car, so that may have also played a factor.
Old Mar 21, 2003 | 07:36 AM
DSimple1's Avatar
Re: Re: Re: Re: EVAP ecu codes
Good deal, thanks for the info!
Old Mar 21, 2003 | 10:27 AM
Phantoj's Avatar
Re: Re: Re: Re: Re: EVAP ecu codes
Hey, in this thread, I described how I removed and cleaned my EVAP vent valve:
http://forums.maxima.org/showthread.php?threadid=198812
Hey, $80 is $80.
Old Mar 22, 2003 | 05:48 AM
DSimple1's Avatar
Re: Re: Re: Re: Re: Re: EVAP ecu codes
Hey, $80 is $80.
That did the trick! I didnt take the whole thing apart, just sprayed in some WD-40, let it soak a little, then worked the valve and the service engine light has not come on since.
Thanks again for all the help!
Old Mar 22, 2003 | 12:29 PM
crazyravr's Avatar
Yeap... that worked for me as well...
The ppl in power on this board should make that write up a sticky and give props to the guy who posted that.
Thanx man.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
tseng1023
Oct 15, 2015 08:30 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
