how much grease when fixing starter noise?
Old Mar 22, 2003 | 08:29 AM
davey6693's Avatar
I followed the excellent write up on motorvate.ca about regreasing part of the starter to get rid of the noise. I paid attention to the part that said "don't overgrease" and for a month or so it's been fantastic. The noise has started to come back now which suggests I've got the amount of grease wrong. Anyone know how much is enough? I added enough to very lightly coat the entire surface of the gears, maybe should have been a bit more.
Old Mar 22, 2003 | 09:40 AM
PedalKick's Avatar
If all you greased was the gears, that was not enough. You also have to remove the pinion gear from the shaft and clean and regrease it. That is the part that gets hung up from the sticky grease. The pinion gear does not disengage from the ring gear fast enough. The pinion gear is the big one that engages the flywheel ring gear. The planetary gears also need grease, but I don't think they contribute to the noise.
Old Mar 22, 2003 | 09:44 AM
davey6693's Avatar
Oh yeah, I misread that. Thanks for the help man.
Old Mar 22, 2003 | 01:49 PM
iwannabmw's Avatar
Make sure you use a high quality high temp. grease as well. If not, the grease will just get cooked and become sticky again.
05RLS2
Sep 27, 2015 09:24 PM
foodmanry
Sep 24, 2015 12:02 PM
pears
Sep 18, 2015 05:25 AM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
