Do I need to replace the fuel filter?
Old Jan 15, 2001 | 04:08 PM
MacGyver's Avatar
I have 100k or so on my 97 SE. I last got my car serviced at the 90k service/check up. I don't think they replaced the fuel filter, but I was reading it should be replaced every 30k miles or so.
Old Jan 15, 2001 | 04:10 PM
max1ma97se's Avatar
i did
pain in the *** tho. took me a half in hour of hard pullin and pushin tha damn fuel line. cost 11 bux at kragen. chea p insurance
Old Jan 15, 2001 | 04:29 PM
got rice?'s Avatar
definately. clean fuel will help the injectors last a little longer by not clogging up.
remember to release all fuel pressure before pulling off the hoses. you can do this by letting the car sit for 8+ hours PLUS removing the fuel tank cap. just to be safe, you can pull the fuel pump relay and crank the car several times.
also wear safety eyewear just in case, plus have a bunch of rags on hand. the fuel lines can be tough to pull off, especially in the position that they are located. heat them up with a heat gun or hair dryer; this makes them more pliable and they'll pull off a little easier. or just cut them and replace with new fuel lines.
Old Jan 15, 2001 | 09:25 PM
dch95's Avatar
Yes you should
Listen to got rice.
Old Jan 15, 2001 | 10:11 PM
bigtexan7's Avatar
replace every 30k like the manual says.
Old Jan 16, 2001 | 04:40 AM
shumax's Avatar
ahhhh
Not to be a di$k but heating a fuel line up with a heat gun is a bit dangerous! I think I would just keep trying to pull. I must be the only one...but this replacement took me 15min. to do....
SHUMAX
Old Jan 16, 2001 | 05:00 AM
got rice?'s Avatar
Re: ahhhh
SHUMAX
what's so dangerous about it? nothing. I've done this process numerous times on different cars. there's no way you screw things up and cause any damage.
Old Jan 16, 2001 | 10:16 PM
Black97GLEnj's Avatar
its easy..
if you have the tool they use at gas stations. The tool looks like a pair of pliers, but instead of holding something, it pushes things apart (like the fuel line from the gas filter).. It has a special head on it to grip the hose.
00MAXI
Sep 2, 2015 10:23 AM
305head
Aug 26, 2015 09:03 PM
homewrecker
Aug 24, 2015 08:56 PM
kirkhilles
Aug 8, 2015 10:53 AM
maxima297
Aug 3, 2015 12:50 PM
