Starting Noise
Old Mar 27, 2003 | 12:29 PM
waveridr85's Avatar
Starting Noise
When I started my car this morning i heard a slight scrape/grind from the starter. Went to school and everything was fine. Got in the car, tried to start it: same grinding type of sound only worse, and no start. After i held the starter it worked and my car was running fine. Got home. Shut the car off and started it again - no problem. What the hell was up w/ that noise?
Specs: 1995 se - 64k
reset ecu tuesday, drove the car bout 50 miles since then w/ no problems
oil changed regurarly
Old Mar 27, 2003 | 12:33 PM
Geophrum's Avatar
Re: Starting Noise
Probably starter needs to be relubed or is going bad
Try this... go to
http://motorvate.ca/
then towords the bottom under added pages go to starter noise fix
worth a try!
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
bennuss
Sep 11, 2015 05:55 AM
trungg86
Sep 4, 2015 04:58 AM
